alternator pulleys = idle problems
Old Dec 28, 2004 | 09:04 PM
luda94's Avatar
Default alternator pulleys = idle problems
After doing all the common checks to figure out why my idle was having the ever so common fluctuation problem between 700 and 1500 rpm's, I discovered that the cause of the problem was my AEM alternator pulleys. The different pulley sizes caused the alternator to spin at a lower speed which did not put out the voltage that it was intended to put out. In order to produce the necessary voltage for operation, my ECM was kicking up the idle to a point higher than needed and then cycling back down and then back and forth continuously. Just thought I'd let everyone know in case they have had similar problems.
Old Dec 28, 2004 | 09:14 PM
prelittlelude's Avatar
Default Re: alternator pulleys = idle problems (luda94)
hmm thats some interesting stuff,
i think the hot idle for the prelude at its very lowest can be 550 maybe a bit higher, and with the aem under drive pulleys that would do what you described
CR3X
Mar 12, 2008 07:17 PM
tweekerz
Aug 12, 2007 08:06 PM
Train
Aug 6, 2007 03:57 PM
mr_gs-r
Mar 1, 2007 10:21 AM
GarageAlchemist
Mar 15, 2006 07:43 PM
