stupid noob question about lower strut bar
Old Dec 28, 2004 | 09:04 PM
civiccrazy93's Avatar
Default stupid noob question about lower tie bar
i just want to know,what exactly do I have to do to install a rear lower tie bar?Is it just unbolt the control arm bolts and then mount it back up?Also,can the tires be free flowing off a lift or should the car be sitting as if it is on the ground?Thanks ppl!
Modified by civiccrazy93 at 10:30 PM 12/28/2004
Old Dec 28, 2004 | 09:11 PM
civictildeath's Avatar
Default Re: stupid noob question about lower strut bar (civiccrazy93)
bwahahahahaha.... i have had one of those sitting in my backseat for a year because i have heard nothing but nightmares about putting them on and the one time i tried i couldnt get the bolt out to install it. good luck and let me know how you got it on if you do
thisisntjared's Avatar
the car cant be on the ground and yes you just unbolt the lca bolts and install but its easier said than done on a civic.... snapping bolts sucks.
also, i dont mean to sound like an ***, but its a lower tie bar because it does not get near a strut or shock at all. it simply ties two points of the chasis.
Old Dec 28, 2004 | 09:24 PM
Default Re: stupid noob question about lower strut bar (bleh)
its cool!thanks for the correction and the info.I was looking at those bolts and they do look as if they are going to be a pain in da *** to get off.Only one way to find out tho!
Old Dec 28, 2004 | 09:27 PM
Default Re: stupid noob question about lower strut bar (civictildeath)
i ll let you know.this sounds as if its gonna be fun.
pb blaster and 10w40 motor oil will be your best friend on it..GOOD LUCK
Old Dec 28, 2004 | 09:31 PM
chads's Avatar
i have taken mine off and on 4 times, longest it has taaken was 2 hours. shortest was 3 min.
hope you wear your lucky underwear!
Old Dec 28, 2004 | 09:41 PM
Default Re: stupid noob question about lower strut bar (chads)
damn!don't say that ****!well,my biggest worry is breaking the bolt.If that **** breaks what the hell do i do?freaking honda dealer is like 1hr away and i don't even have a second car right now.
Old Dec 28, 2004 | 09:43 PM
i would caot the **** out of the bolts with some motor oil and let it sit for a hour or so and then try to bust loose. if/when it gets hard to turn add more oil. repeat
KGB_JDM
Feb 11, 2010 06:54 AM
Froznface
14
Jan 25, 2006 05:49 AM
ctownintegra
Suspension & Brakes
Feb 4, 2005 04:43 PM
Calsonic180
Jan 24, 2005 09:48 PM
K-Bom05
Nov 23, 2002 01:29 AM
