rev limiter
Today i reved my car to like 8 in 2nd gear but it didnt hit a rev limiter. Is that bad? and it felt like it was still pullin after 7500. When do the rev limiters kick in on 5th gens?
Every dyno sheet I've seen for preludes without extreme modification shows that power drops off around 7200. As far as a rev limiter, there's no reason you should be revving that high, unless you wanna stretch your rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion »</TD></TR><TR><TD CLASS="quote">Sounds like your tach was off...</TD></TR></TABLE>
right on
right on
If it was still pulling after 75, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion »</TD></TR><TR><TD CLASS="quote">Sounds like your tach was off...</TD></TR></TABLE>
Also, the limiter is at 82 I believe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hif7 »</TD></TR><TR><TD CLASS="quote">If it was still pulling after 75,
Also, the limiter is at 82 I believe</TD></TR></TABLE>
8200
8200
On the tach, yes, maybe 8200rpm depending on how off it is. In real engine speed, 76xx rpm.
Adi
Adi
how dangerous is it to take an h22a4 to rev limit without any modifacations, totally stock 00 SH, I haven't done it just for fear of bending a valve which might have happened on a miss-shift anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX »</TD></TR><TR><TD CLASS="quote">how dangerous is it to take an h22a4 to rev limit without any modifacations, totally stock 00 SH, I haven't done it just for fear of bending a valve which might have happened on a miss-shift anyway</TD></TR></TABLE>
It would probably be ok but there is no reason to rev that high b/c you wont make any power way up there, so why even chance it. It would be best for you to stay fearful of winding that high.
It's not recommended to hit it, but that is what it's there for. Bending valves is when you miss-shift and mechanically the engine has to go above 7800 rpms no matter how much fuel and ignition you cut
Yes well I think I miss-shifted 3 days after I bought the car... it still idles and runs great but the car feels like it has lost a lot of power... I don't know what to do. I hear a lot of ticking from the valve cover but my honda dealership said it was normal. I think they are full of it. Any suggestions? My tools are limited.
