built sleeved b20 vtec with high compression + supercharger...safe?
Old Dec 28, 2004 | 06:55 PM
Rice Is Best's Avatar
Default built sleeved b20 vtec with high compression + supercharger...safe?
a sleeved b18 with 85mm bore and 89mm crank along with a type r head and 11.__:1 compression with buddy club 4s or jun 3s...would it be safe to supercharge it?
i pick supercharger so theres no intercooler and the nice "psssshhhh" hehe
which would be better jrsc or vortech?
would the extra displacement help alot with the supercharger?
Old Dec 28, 2004 | 07:17 PM
b20vtecEK's Avatar
Default Re: built sleeved b20 vtec with high compression + supercharger...safe? (KockAsian)
your not going to be able to run pump gas on sky high compression and boost. Why so high comp??
Old Dec 28, 2004 | 07:35 PM
Default Re: built sleeved b20 vtec with high compression + supercharger...safe? (b20vtecEK)
93 octane if thats any help...
how high does the compression become when a supercharger is aded to a 11:1 compression?
Old Dec 28, 2004 | 07:37 PM
b20vtecEK's Avatar
no listen, your not going to be able to run pump gas with through the roof compression and boost. Adding boost doesnt change the motors compression ratio. New to this much???
Old Dec 28, 2004 | 08:40 PM
jdm itr motors come with 11:1 compression. and ive seen 12:1 all motor motors run 93 gas.
Old Dec 28, 2004 | 08:46 PM
ek9800's Avatar
all motor= high compression
Forced Induction= Lower Compression comprende?
Old Dec 28, 2004 | 09:48 PM
lumpbuzcut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KockAsian &raquo;</TD></TR><TR><TD CLASS="quote">jdm itr motors come with 11:1 compression. and ive seen 12:1 all motor motors run 93 gas.</TD></TR></TABLE>
but not with a supercharger or any sort of forced induction. cant go 2 different roads at the same time, it's either N/A or Turbo, take your pick.
Old Dec 29, 2004 | 08:28 AM
Default Re: built sleeved b20 vtec with high compression + supercharger...safe? (lumpbuzcut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lumpbuzcut &raquo;</TD></TR><TR><TD CLASS="quote">but not with a supercharger or any sort of forced induction. cant go 2 different roads at the same time, it's either N/A or Turbo, take your pick.</TD></TR></TABLE>
yeah but isnt it safe to supercharger a stock itr motor? its high compression. as long as its tuned isnt it ok?
Old Dec 29, 2004 | 08:30 AM
JDMlyfestyle's Avatar
ya its safe to supercharge your motor. but you wont have very good results seeing that the BC spec IV are great all motor cams i dont believe they will like the supercharger a whole lot.
Old Dec 29, 2004 | 09:02 AM
Luserkid's Avatar
Default Re: (JDMlyfestyle)
You could do it but you cant do it with stock ecu w/hondata or anything like that. You need something like AEM EMS or DEFI or **** like that.
Its all in the tuning. So basically if you have alot of money it can be done.
Old Dec 29, 2004 | 09:17 AM
Triscuit's Avatar
Default Re: (Luserkid)
also you would have to build up your supercharger to be able to handle those rpms with the BC cams or Jun's. While your redline may only be 8k on a stock motor the compressor fins on the supercharger are spinning at maybe 10k-11k. At that rpm the supercharger becomes inefficient (spelling). In other words you'll be compressing hot air which is not good. If you wanna make power get a simple turbo setup with a decient size turbo (SC61). Oh yea I'm not turbo bias this is comming from a person who is Supercharged
Old Dec 29, 2004 | 10:04 AM
Default Re: (Ronin EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin EG6 &raquo;</TD></TR><TR><TD CLASS="quote">also you would have to build up your supercharger to be able to handle those rpms with the BC cams or Jun's. While your redline may only be 8k on a stock motor the compressor fins on the supercharger are spinning at maybe 10k-11k. At that rpm the supercharger becomes inefficient (spelling). In other words you'll be compressing hot air which is not good. If you wanna make power get a simple turbo setup with a decient size turbo (SC61). Oh yea I'm not turbo bias this is comming from a person who is Supercharged </TD></TR></TABLE>
with the vortech supercharger, theres an optional intercooler of some sort i forgot the name of it.
it shouldnt be blowing in hot air like the jackson racing does.
im thinking that if a vortech supercharger works on a high compression stock engine like the type r, it should work on a same compression but more displacement engine like a b20 type r.
Old Dec 29, 2004 | 10:29 AM
Triscuit's Avatar
Default Re: (KockAsian)
Vortech SC's are just like N/A cars they make all their power almost close to redline. If you wanna go SC I say do a b20/vtec with 10:2.1 compression and run the 10psi stepper pulley (JRSC), which will bump it up to 12psi with the b20 crank pulley. I'm running 9:5.1 compression with a sri, 2.5 4-1 header, 2.5 test pipe, and 2.5 exhaust 6psi and making 205whp. So 10:2.1, i/h/e, 12psi, on a B20/vtec will put down some decient numbers and gobs of torque.........
spoonEGcivichatch
Sep 18, 2005 09:51 AM
i20ar
Sep 17, 2005 12:48 PM
TehMoonRulz
May 16, 2005 01:15 PM
GRTechnologies
Aug 11, 2003 07:20 AM
HX_Guy
Dec 6, 2001 03:24 PM
