whats ur oil pressure reading?
Old Dec 28, 2004 | 06:45 PM
boosted k20's Avatar
Default whats ur oil pressure reading?
what Oil pressure are u guys seeing while driving at around 3K on the highway? is 40-50 PSI normal
Old Dec 28, 2004 | 07:43 PM
Dan GSR's Avatar
Default Re: whats ur oil pressure reading? (boosted k20)
at idle, i get around 30
at 3k, i have about 60-70, and will go up to 80-90psi at the upper most rpm
Old Dec 29, 2004 | 08:59 AM
cjohnson_2's Avatar
Default Re: whats ur oil pressure reading? (Dan GSR)
at idle with mine its about 20psi. 50psi sounds right for regular driving on mine. Then around 75-80 psi at WOT
Old Dec 29, 2004 | 10:29 AM
96_GSR's Avatar
Default Re: whats ur oil pressure reading? (cjohnson_2)
20-25 at idle..50 at 3k.
Old Jan 2, 2005 | 12:37 AM
gt30typer's Avatar
I usually run about 70psi cruising on the highway, almost 80 under full load and around 30 at idle. As long as you are above 50 psi at 3000 you are okay , at least that is what the factory service manual says. VTEC takes about 64 psi to function if you are using a pressure switch. 40 to 50 seems a little low , oil pump or main bearing clearances have probably increased a bit.
Old Jan 4, 2005 | 08:01 PM
Default Re: whats ur oil pressure reading? (gt30typer)
yea, the oil clearance was checked and it was over the service limit. i think it was .003 inches. that seems to be the cause of the problem. the crank in the block right now is not the stock one so the codes on the crank and block cant tell me which main bearings to get. i guess i'll have to go one size bigger in the bearing. right now it's run n ACL main bearings which is honda green. which color is the next one over? brown, yellow, etc.????
tonydize21
Jun 18, 2011 01:23 AM
spoolinlude
May 26, 2011 05:46 AM
RACEPAK
Jul 6, 2009 07:53 PM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
ablangc
Oct 24, 2002 06:21 PM
