WON'T GO INTO REVERSE
Old Dec 28, 2004 | 05:24 PM
teds95gsr's Avatar
Default WON'T GO INTO REVERSE
I had an ACT stage 1 clutch installed about a month ago. Everything was fine until Friday. On my way home I went to put it into fifth and it went in kinda hard. I didn't think much o fit until I got home. When I went to leave it wouldn't go into reverse. Every other gear is fine, it moved the car a little tonight. I checked the linkage going into the tranny and everything looks good. I'm thinkin maybe internal linkage. The car has 187K on it. Anyone have this problem?
If it does need a tranny will a 6 speed type R work? it's a '95 gsr
Old Dec 28, 2004 | 05:27 PM
thaiphob's Avatar
Nikon!!!
Default Re: WON'T GO INTO REVERSE (teds95gsr)
type Rs dont have a 6sp tranny
Old Dec 28, 2004 | 05:57 PM
MassScene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teds95gsr &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> If you find a 6speed tranny for b series holla back!
Old Dec 28, 2004 | 06:16 PM
bg-33p's Avatar
i have a similar problem..but mines just wont go into any gear at all..what could be the problem?
Old Dec 28, 2004 | 06:25 PM
CNSK's Avatar
Default Re: WON'T GO INTO REVERSE (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">i have a similar problem..but mines just wont go into any gear at all..what could be the problem?</TD></TR></TABLE>
clutch could be out...mine did the same thing...
Old Dec 28, 2004 | 07:46 PM
Dan GSR's Avatar
if it suddenly won't go into any gear with the engine running
but when the engine is off, it will go into every gear, than the problem is the clutch/pressure plate is broken
Old Dec 28, 2004 | 07:47 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teds95gsr &raquo;</TD></TR><TR><TD CLASS="quote">I had an ACT stage 1 clutch installed about a month ago. Everything was fine until Friday. On my way home I went to put it into fifth and it went in kinda hard. I didn't think much o fit until I got home. When I went to leave it wouldn't go into reverse. Every other gear is fine, it moved the car a little tonight. I checked the linkage going into the tranny and everything looks good. I'm thinkin maybe internal linkage. The car has 187K on it. Anyone have this problem?
you my friend, have broken your 5th/reverse syncro
Old Dec 28, 2004 | 08:00 PM
a1320addict's Avatar
Default Re: WON'T GO INTO REVERSE (MassScene)
happens to me too...put it in first then into reverse...sometimes the gear box gets a lil stubborn...try that it always works for me
Old Dec 28, 2004 | 08:11 PM
LANEVOIX's Avatar
most likely your clutch or synchros...6 sp. tranny...bwahahhaha
Old Dec 28, 2004 | 09:12 PM
Senbonzakura's Avatar
Default Re: WON'T GO INTO REVERSE (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">you my friend, have broken your 5th/reverse syncro</TD></TR></TABLE>
Hahahahah....
Old Dec 28, 2004 | 09:25 PM
aznsins88's Avatar
my guess is syncros so get tht checked out. Hope all goes well and if you do find a 6-speed b-series tranny then holla man
~Eric
Old Dec 29, 2004 | 01:17 PM
bg-33p's Avatar
but when the engine is off, it will go into every gear</TD></TR></TABLE>
thats exactly my problem, thanks man..
Old Dec 29, 2004 | 02:08 PM
DOHCGsr's Avatar
do what yehiknowrite said, put in first, move the car a couple of inches, then it should slip rite in reverse. always works for me. gl
Old Dec 29, 2004 | 02:54 PM
tegsallgood's Avatar
Default Re: WON'T GO INTO REVERSE (DOHCGsr)
i just take the lutch out then put it back in always slips right in- it NEVER goes in the first try
Old Dec 29, 2004 | 03:12 PM
FULL-REV's Avatar
i put mine in 4th then reverse and it goes in everytime
Old Dec 29, 2004 | 05:25 PM
vart's Avatar
Default Re: (hondaevo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaevo &raquo;</TD></TR><TR><TD CLASS="quote">i put mine in 4th then reverse and it goes in everytime</TD></TR></TABLE>
me too, damn syncros.
Old Dec 29, 2004 | 05:42 PM
blusmke's Avatar
no b series but you could spend a **** load of money an a k series
Old Jan 22, 2021 | 03:20 AM
carlowerks's Avatar
its a bent scha
k20rsx1
Jul 13, 2009 06:21 PM
prolifik22
Dec 22, 2007 11:00 AM
oem_certified_accord
Aug 22, 2007 09:23 PM
95gsr
Sep 13, 2003 04:06 PM
