oem Honda Alarm Install Problem!!!
i bought the factory alarm from H and A accesories for my 00 civic si and installed it tonight in the freezing cold. Its just an added upgrade to keyless entry. Anyway the alarm arms and i tested the doors/truck/hood and it the horn goes off like its supposed to. HOWEVER the LED doe not blink when arming, disarming, or when the alarm is actually going off. The only time the LED lights up is when the car is on and running. It just flashes rapidly and never stops until the car is off, and when it flashes it lights up very dull.. Can someone point me in the right direction!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi »</TD></TR><TR><TD CLASS="quote">i bought the factory alarm from H and A accesories for my 00 civic si and installed it tonight in the freezing cold. Its just an added upgrade to keyless entry. Anyway the alarm arms and i tested the doors/truck/hood and it the horn goes off like its supposed to. HOWEVER the LED doe not blink when arming, disarming, or when the alarm is actually going off. The only time the LED lights up is when the car is on and running. It just flashes rapidly and never stops until the car is off, and when it flashes it lights up very dull.. Can someone point me in the right direction!!!</TD></TR></TABLE> Not sure what the problem is, but as it is wired to the alarm, I would say the problem is in the alarms brain, and if it works, [the alarm] then it may be just the LED output of the brain.
94
94
do you have to reprogram the keyfob?? even though keyless comes with the car and the alarm functions as it should???
i never reprogrammed it!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi »</TD></TR><TR><TD CLASS="quote">do you have to reprogram the keyfob?? even though keyless comes with the car and the alarm functions as it should???
i never reprogrammed it!!!</TD></TR></TABLE>If the alarm is working, you will not need to reprogram the remote, the problem with the LED will have nothing to do with the remote, are you also haveing a problem with the keyless entry?
94
94
i got the alarm from...
http://www.handa-accessories.com/
and they sent me a knew one, and i'm waiting for it.
everything worked fine but the LED itself.
