how do you crank the motor when it's out of the car?
Old Dec 28, 2004 | 04:52 PM
1.8's Avatar
1.8
Default how do you crank the motor when it's out of the car?
anyone know? TIA.
Old Dec 28, 2004 | 04:57 PM
shadowchild's Avatar
Default Re: how do you crank the motor when it's out of the car? (1.8)
What do you wana do exactly, and we talking cranking it up, or turning the engine over ? if you want to actually move the crank just put a wrench on the crank pully and turn to your hearts content. if you pull the sparkplugs it will become a lot easier as you will no longer have to fight the engines compression.
Old Dec 28, 2004 | 04:59 PM
agCrX's Avatar
Turn the Crank by the bolt, depending on the motor there will be a 17mm or 19mm bolt holding the crank pulley on. Get a socket on that bolt and crank away. Make sure you go counter clockwise (loosen) if the bolt is on there correctly it will not come loose while you are turning. Also if the head is attached to the block, make sure that you do not move the crank or cam out of sync, if you do this this is a possibility you can mess up your valves. If you are doing a timing belt it is a good idea to leave the spark plugs in, it will make it harder to turn the motor but will make it hold its position better, if not, then by taking the spark plugs out you will turn the motor over much easier due to loss of compression just FYI.
Hopefully that will help
Old Dec 28, 2004 | 05:15 PM
1.8's Avatar
1.8
Default Re: how do you crank the motor when it's out of the car? (agCrX)
my distributor cap is broken and i want to replace that along with the rotor. the rotor screw is not where it should be. that's why i want to turn it over.
but u guys are saying i might mess up my valves? maybe i shouldn't do it then.
should i take out the spark plugs?
Old Dec 28, 2004 | 05:24 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">my distributor cap is broken and i want to replace that along with the rotor. the rotor screw is not where it should be. that's why i want to turn it over.
should i take out the spark plugs?</TD></TR></TABLE>
If your timing belt is intact and properly timed, you won't damage anything. Pull the plugs if you want (to eliminate compression), but it isn't necessary to do so.
Old Dec 28, 2004 | 05:27 PM
1.8's Avatar
1.8
Default Re: how do you crank the motor when it's out of the car? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If your timing belt is intact and properly timed, you won't damage anything. Pull the plugs if you want (to eliminate compression), but it isn't necessary to do so. </TD></TR></TABLE>
yeah, my timing belt is intact and properly timed. so basically just pull out spark plugs and turn the crank bolt? that easy?
wouldn't the crank bolt come loose if i turn it?
Old Dec 28, 2004 | 05:33 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, my timing belt is intact and properly timed. so basically just pull out spark plugs and turn the crank bolt? that easy? </TD></TR></TABLE>
yes. make sure you crank it counter clockwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't the crank bolt come loose if i turn it?</TD></TR></TABLE>
haha no way. you're in for a hell of a surprise when you try to get that bolt off at some point later on.
Old Dec 28, 2004 | 05:35 PM
1.8's Avatar
1.8
Default Re: how do you crank the motor when it's out of the car? (jwn7)
thanks guys!!
Old Dec 28, 2004 | 05:42 PM
KillerTofu's Avatar
You can still rotate the rotor without having to manually crank the engine. With your key in the ignition just partially turn the motor over. Do not!! I repeat do not crank the motor all the way. Each time you turn it, the rotor will be in a different location. Good luck.
**** forgot about the rest of the title. Reading owns me.
Modified by uncivical at 6:56 PM 12/28/2004
Old Dec 28, 2004 | 05:59 PM
KillerTofu's Avatar
Yes Cupcake I forgot about the rest of the title.
Old Dec 28, 2004 | 06:05 PM
ABK's Avatar
ABK
Default Re: how do you crank the motor when it's out of the car? (uncivical)
or you could just take of the distributor... and time it later on, which is a wise idea if you are putting the motor into a car anyways.
wsudu
Nov 10, 2016 03:00 PM
radfanjam
Honda Civic (2001 - 2005)
Jun 23, 2016 08:56 PM
protopro88
Apr 12, 2011 04:31 AM
str8JDMteggy
Jan 7, 2007 08:41 AM
ent1016
Aug 8, 2004 02:50 PM
