Trying to wire up power locks to unlock passenger side while inside car. How do I do this?
Old Dec 28, 2004 | 04:26 PM
d15maverick's Avatar
Default Trying to wire up power locks to unlock passenger side while inside car. How do I do this?
I have power locks with my alarm. They only lock when i arm and disarm the alarm. I wanted to put a switch in the car so I can unlock the passenger door while the car is still running. Im annoyed whenever I cut off the car and both doors unlock. Or when I need to let in my friends in , I still have to reach over to unlock the door. How can I accomplish this? TIA.
Old Dec 28, 2004 | 05:20 PM
Double_Dk's Avatar
Default Re: Trying to wire up power locks to unlock passenger side while inside car. How do I do this? (d15m
Check out this link.
http://www.the12volt.com/doorlocks/page3.asp
Your doing this with actuators right? Your gonna need Relays for that.
Now if you wired your alarm to the IGN, you should be able to "ARM/DISARM" without triggering your alarm so basically "LOCK/UNLOCK"
Hope that helped.
Old Dec 29, 2004 | 12:39 PM
1gEF-8's Avatar
all you need is a double momentary switch. there should be three prongs. connect the center to ground , one to lock ,and one to unlock wires coming from the alarm. most alarms the lock/unlock wires are blue and green
droopy128
Sep 22, 2018 05:47 AM
droopy128
Audio / Security / Video
Sep 19, 2018 02:29 AM
slowturtle
Apr 29, 2005 06:59 AM
TurBoXBirD16
Feb 25, 2002 02:36 PM
