**ALL MOTOR B-SERIES PARTS** ROCKET MOTORSPORTS, TODA
Old Dec 28, 2004 | 03:10 PM
itralex's Avatar
Default FS: **ALL MOTOR B-SERIES PARTS** ROCKET MOTORSPORTS, TODA
Valve Springs
Rocket Motorsport Valvesprings
Model: Gen 2
Specs: Gen2 springs have 55 lbs. on the seat and 180 lbs. at 12mm of lift. These springs can handle up to 14mm of lift when used with the Gen2 retainers
linear Rates
7000km on springs
retails: $165 USD (200 CDN)
my Price $150CDN obo
Valves
Intake valves have the same underhead as the Type-R and a stemmed down neck to increase flow.It also has a thinner margin to increase valve to valve clearance and reduce weight.
Exhaust valves are two piece and utilize an inconel head which can withstand extremely high temperature.
All valve stems use the same metal as OEM valves which prevent the tips from mushrooming.
Raises compression ratio 0.3-0.5 points depending head setup
5000km
retails: $250 USD (305 CDN)
My Price: $225CDN obo
Cams
Toda Spec C cams
specs: IN 250 (11.0) - 295 (12.5) - 250 (11.0)
EX 250 (11.0) - 295 (12.5) - 250 (11.0)
operates best with CR above 12.5
but will still make good power with cr just under 11.0
7000 km
Retail: $1100 USD (1341 CDN)
My Price $950CDN obo
All prices do not include Shipping
Paypal is accepted with a 3% charge
Old Dec 28, 2004 | 11:44 PM
itralex's Avatar
Default Re: FS: **ALL MOTOR B-SERIES PARTS** ROCKET MOTORSPORTS, TODA (HypeR1004)
ttt
Old Jan 6, 2005 | 08:49 AM
TeStUdO's Avatar
Pm sent
eTiLiKo
13
Mar 5, 2010 07:49 AM
sinister6
May 4, 2006 04:11 AM
B16CRXSi
Nov 3, 2003 10:14 AM
AllmotorJunkie
Mar 6, 2003 01:17 PM
mugenintegra16
Feb 13, 2002 05:45 AM
