-> GSR clutch with different motor/trans ???
Old Dec 28, 2004 | 01:59 PM
jfoster's Avatar
Default -> GSR clutch with different motor/trans ???
Well, I originally planned to turbo my '01 GSR so I bought an Action 2MD clutch for it. Since then I have decided to purchase a shell and build a motor to put in it and turbo....so my '01 can stay untouched.
I plan to build an LS/Vtec for it. It is my understanding that I can still utilize the GSR 2MD I bought so long as I run a GSR flywheel and GSR tranny.....correct?
But it can't be used with an LS trans?
Nor a B16 tranny?
Will any GSR trans work ? Regardless of year, or USDM or JDM ????
Thanks
Old Dec 28, 2004 | 07:29 PM
jfoster's Avatar
Default Re: -> GSR clutch with different motor/trans ??? (jfoster)
anybody?
Old Dec 28, 2004 | 07:58 PM
Dan GSR's Avatar
the clutch you purchased will work for any B series engine, and any B series hydraulic transmission
Old Jan 1, 2005 | 06:21 PM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">the clutch you purchased will work for any B series engine, and any B series hydraulic transmission</TD></TR></TABLE>
Seriously? Regardless of flywheel? Or whether its LS/GSR/ITR/B16 trans, so long as its hydraulic and Bseries huh..... that is good news.
I swear somebody told me it would only work with a GSR flywheel and GSR trans
Old Jan 2, 2005 | 01:46 PM
boricuatuning's Avatar
Just make sure you use the same flywheel.I know the ls fly has less pressure plate bolts then a b16 fly.
Old Jan 2, 2005 | 03:33 PM
jfoster's Avatar
Default Re: -> GSR clutch with different motor/trans ??? (boricuatuning)
Alright, well since I was under the impression it would only work with a GSR trans and GSR flywheel I have already bought a GSR flywheel.....so thats no problem.
But I need to be certian as to what transmition(s) the clutch is compatible with.....because the much cheaper option of an LS trans might end up being what I want to do.... ??? ...
Just lookin for a 2nd person to back up the statement that it would work with any Bseries hydro tranny....before I go shopping
Old Jan 2, 2005 | 04:03 PM
Dan GSR's Avatar
Default Re: -> GSR clutch with different motor/trans ??? (Dan GSR)
93si-hybrid
Jul 7, 2004 12:39 PM
dwn-shift
Jun 23, 2003 02:37 PM
LDxShyGuy
May 27, 2003 12:52 PM
