High idling problem! What is this hole?
Hey guys there is a hole inside of my throttle body like when your lookin at it inside its off to the right.. Like a little slanted hole. Well its making a loud breathing sound and my car is idling at 3000rpms. Is that hole supposed to be plugged? As soon as i plug it with something the idle goes down to 850rmps? WHAT GOES THERE AH! The worse is pulling up to a drive threw and them telling me they cant here me haha gotta love the lude. But seriously someone help me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude »</TD></TR><TR><TD CLASS="quote">one of those black vacuum plugs you need</TD></TR></TABLE>
No, he's talking on the inside diameter of the TB. That hole does go to your fast idle thermo valve which is the thing on the bottom of the TB with the coolant hoses going to it. Take the TB off and then either adjust the FITV or put a metal plate in there so the hole that you're talking about won't reach the FITV.
It that def the problem tho? i froze my *** off today trying to get this problem fixed.. Someone told me it could be my tps or something behind my intake manifold. I unplugged my tps sensor.. Nothing.. I unplugged that plug behind my intake manifold and my idle went back to normal.. but then i tried to drive to check and it and yea that was not a good idea. I have been doin everything myseld lately instead of a shop but this is gettin out of hand.. Guess ill take the throttle body off tomorrow and then go buy a gun ha thanks
the TB gasket is a peice of freaking paper. You dont need to replace it every time you pull the TB off. You should only have to replace it if you tore the **** out of it.
I had the same problem once, and yess its the Fast idle valve....
its usually under the TB, there is some sort of a plastic ring inside of it, usualy i guess honda puts some locktite or something in there...but sometimes it comes loose....just turn it like a screw to tighten it back in and you should be alright...
the thing is the valve is probably always open....
and it idles really high until temp goes up...then once its at temp...it prolly goes back down to normal...or some what normal idle....
estimated time 1/2 hour if your fairly skilled
Takumi Fujiwara
Dec 25, 2005 10:26 AM
