Peicing together turbo kit, need help.
Im peicing together a turbo kit for my civic. Here is what i have so far, what else do i need?
Drag Turbo Manifold
Tial 38mm Wastegate
T25 turbo with adaptor plate
Oil feed and drain lines
all fittings and bolts
20x3x8 FMIC
Section of 2.5" flex pipe to use as down pipe section
2.5" hoses(rubber) for IC piping
3" intake pipe
Cone filter
Im also picking up stock 240cc DSM injectors, Manual boost controller, Wlbro 190 or 255 lph Fuel pump.
What do you think of the setup so far and what else do i need until i can afford hardpiping, 2.5" downpipe, and a greddy Type-RS BOV.
Drag Turbo Manifold
Tial 38mm Wastegate
20x3x8 FMIC
3" intake pipe
Cone filter
your gonna need something to control the fuel to .
240 cc injectors from a dsm huh, you might need bigger ones, unless if you mean dsm 450's.
Dumptube for the wastegate
Missing link or check valves
Misc. vaccum lines
Exhaust flange to bolt to the T28 for the downpipe
Definitely get a BOV, first gen DSM you can get cheap
Misc. vaccum lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harwood39 »</TD></TR><TR><TD CLASS="quote">what is a missing link/check valve</TD></TR></TABLE>
They are used to prevent the MAP from seeing boost which will throw a CEL. You def. need some sort of fuel management as mentioned, at very least an FMU.
jkaz
111
Aug 19, 2007 07:22 AM
Ri5e
Aug 26, 2004 03:31 PM
OG SHG_EM1
Mar 28, 2004 09:10 PM
