My Xmas gift to myself:)
Old Dec 28, 2004 | 10:12 AM
ebpcivicsi1234's Avatar
Default My Xmas gift to myself:)
What a pain in the *** this can be sometimes...iam in the garage for 4 hrs a day but maybe i just take to many breaks...here are some pics...I have some qustions though...I want to run about 7-8 lbs and thats is should i get a boost controller and what kind...Where Do i tap in for my boost gauge and my blow off valve?And what do the top and side ports on the wastegate go to?And I installed my rc 550 injectors and there just black wires on my obd1 clips does it matter what wire goes to what? thanks here are the pics
Old Dec 28, 2004 | 10:15 AM
CivicEJ1's Avatar
Default Re: My Xmas gift to myself:) (ebpcivicsi1234)
Old Dec 28, 2004 | 10:19 AM
Drag_On's Avatar
Everything looks slick except for the Si sticker on the wire cover.
Old Dec 28, 2004 | 10:25 AM
Default Re: (Drag_On)
Yeah iam going to get a cf cover sometime when ever i get this thing together
Old Dec 28, 2004 | 10:36 AM
IN VTEC's Avatar
For an external wastegate, you would use both. Side port goes to boost reference (before or after throttle plate is ok), and the top port comes in from the boost controller solenoid (COM port).
You use the NC solenoid port for external wastegates and it also goes to a boost reference (before or after throttle plate is ok).
The boost gauge has the ability to also read vacuum and boost, so it needs to be referenced to the intake manifold (after the throttle plate). Same goes for your BOV.
The injectors clips don't have polarity. Make sure that the injectors are saturated/high-impedance units if you're not alredy using a resistor pack.
Take some time to secure your steel braided lines or at least firesleeve the them if they have to be rubbing against stuff or close to sources of heat.
Old Dec 28, 2004 | 10:37 AM
W O T's Avatar
Default Re: (ebpcivicsi1234)
its not a thing
ITS A BEAST!!
Really hot man, are you going to do the entire carpet in red?
Manifolds lookin blingin
Wish I had the facilites to store a project car
Good luck
Old Dec 28, 2004 | 10:42 AM
Default Re: My Xmas gift to myself:) (IN VTEC)
the carpet is oem ek9 ctr carpet not worth the money now that i got it..
*****For an external wastegate, you would use both. Side port goes to boost reference****
Side port as boost refence iam confused so like it my turbo had a hold tap in the sidfe like most do since mine doesnt where would i want to get it from then
****You use the NC solenoid port for external wastegates and it also goes to a boost reference (before or after throttle plate is ok).****
What is the Nc port????where do i get something to cover my lines with so i dont met anything or rub agianst anything i dont like the looks of the silver stuff that i have seen
Old Dec 28, 2004 | 10:44 AM
Rod.'s Avatar
Default Re: (W O T)
look like the oil return line will be to long...who knows
Old Dec 28, 2004 | 10:47 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (redturbocivic)
looks way too long...also id mount to the turbo , and make sure you get the right angle for the return line , i didnt and my downpipe hit it.....
Old Dec 28, 2004 | 11:09 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 &raquo;</TD></TR><TR><TD CLASS="quote">Side port as boost refence iam confused so like it my turbo had a hold tap in the sidfe like most do since mine doesnt where would i want to get it from then</TD></TR></TABLE>
You can use a Golden Eagle vacuum manifold and tee into the brake booster line before the check valve to supply everything with vacuum and boost sources. That's probably the easiest way to do it. Any other way would involve a lot of drilling & tapping or a lot of tee'ing off of vacuum lines that are too small to be spread so thin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 &raquo;</TD></TR><TR><TD CLASS="quote">What is the Nc port????</TD></TR></TABLE>
The NC port is found on the electronic boost controller's wastegate solenoid....you have to have one first. I'm partial to the A'pexi AVC-R over the GReddy Profec Spec B II, altho I've used both and either works well to control target boost levels and wastegate doody cycle.
If you don't plan on running an EBC, then you can just hook up the wastegate side port directly to the vacuum manifold. Leave the top port vented to atmospheric pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 &raquo;</TD></TR><TR><TD CLASS="quote">where do i get something to cover my lines with so i dont met anything or rub agianst anything i dont like the looks of the silver stuff that i have seen</TD></TR></TABLE>
Goodridge and Aeroquip both make a variety of firesleeving in orange and other colors. Use .44" ID since -4AN is roughly .425" to .430" OD I think. http://www.racerpartswholesale.com
or PM Stan (Flamenco-T) for the Goodridge stuff...but I'm not sure if he stocks any of that stuff since a lot of people probably don't buy it.
Modified by IN VTEC at 2:20 PM 12/28/2004
Old Dec 28, 2004 | 11:12 AM
el arbi's Avatar
Sweett
Old Dec 28, 2004 | 11:25 AM
DRAGLS's Avatar
Default Re: My Xmas gift to myself:) (CivicEJ1)
By the way your eprom is installed backwards theres a arrow on it; it faces towards the harness
Old Dec 28, 2004 | 11:31 AM
IN VTEC's Avatar
Default Re: My Xmas gift to myself:) (DRAGLS)
Good catch.
Old Dec 28, 2004 | 11:50 AM
MooreBoost's Avatar
Your feed line looks massive too.
I would swap for a -3an or run a restrictor.
Old Dec 28, 2004 | 11:59 AM
Tactic$'s Avatar
Very nice catch indeed
Old Dec 28, 2004 | 12:03 PM
H.A.R.T B18C1EG6's Avatar
Default Re: My Xmas gift to myself:) (Tactic$)
looks like a nice setup.... good luck
Old Dec 28, 2004 | 12:09 PM
11psiTurboSI's Avatar
Default Re: My Xmas gift to myself:) (H.A.R.T B18C1EG6)
Nice set-up
TeggieeTuner
Feb 19, 2011 01:37 PM
sevenj
May 24, 2008 06:14 PM
Kid1320
Aug 31, 2005 05:23 AM
Goldfingiz
Jan 19, 2003 07:23 PM
Kamin
Sep 11, 2002 08:46 PM
