00si(b16) putting PCT pistons..do i need to shave off 1mm on each sides..
Old Dec 28, 2004 | 09:28 AM
hi-Powered's Avatar
Default 00si(b16) putting PCT pistons..do i need to shave off 1mm on each sides..
of the small end of connecting rod...or just put in the pistons..
thanks
Old Dec 28, 2004 | 09:48 AM
Combustion Contraption's Avatar
yes you need to shave off 1mm.
Old Dec 28, 2004 | 11:01 AM
Scotty B's Avatar
Default Re: (LsVtec92Hatch)
Yup 1mm off each side...Then have evrything balanced..
Old Dec 28, 2004 | 12:37 PM
Terrible One's Avatar
Default Re: (nasi)
off topic, which stock rods require shaving off 1mm when running pistons; pr3, p30, pct, p73 etc
Old Dec 28, 2004 | 01:14 PM
Hybrid96EK's Avatar
Default Re: (orig1nalkhmersta)
Seems no one here clarifyed the answer to his question.
You shave the RODS not the pistons.
There is NO need to "balance" everything afterwards
Old Dec 28, 2004 | 01:16 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orig1nalkhmersta &raquo;</TD></TR><TR><TD CLASS="quote">off topic, which stock rods require shaving off 1mm when running pistons; pr3, p30, pct, p73 etc</TD></TR></TABLE>
Just what the hell are you asking here? PR3 and P30 "rods" would be identical... In fact, I don't think there is such a thing as P30 rods, they would simply be P30 rods. Same with PCT, no such rod with that part number... You listed a bunch of PISTON part numbers asking which one of them would need to be shaved. Agian, you are not shaving the piston, you shave the rod. Only needed on the B16/B17 setups.
Old Dec 28, 2004 | 01:19 PM
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Just what the hell are you asking here? PR3 and P30 "rods" would be identical... In fact, I don't think there is such a thing as P30 rods, they would simply be P30 rods. Same with PCT, no such rod with that part number... You listed a bunch of PISTON part numbers asking which one of them would need to be shaved. Agian, you are not shaving the piston, you shave the rod. Only needed on the B16/B17 setups.</TD></TR></TABLE>
whoops, i meant which 1.8L (b18b's,b18c's) rods, sorry
Old Dec 28, 2004 | 01:29 PM
Hybrid96EK's Avatar
whoops, i meant which 1.8L (b18b's,b18c's) rods, sorry</TD></TR></TABLE>
As far as I know, none of them require modification. I know for a fact the B18c's do not require any work.
Old Dec 28, 2004 | 01:48 PM
EKhatch's Avatar
B16A and B18A/B rods are 20mm wide while B16B and B18C rods are 18mm wide at the small end.
turbo-crx
Apr 18, 2008 09:08 AM
d16dcoe45
Sep 27, 2006 05:15 PM
MI4$DC5
Mar 5, 2005 04:56 PM
kenepo_vtec
Sep 26, 2004 02:22 PM
