After my straight pipe install...
Old Dec 28, 2004 | 09:11 AM
85mm LS VTEC's Avatar
Default After my straight pipe install...
I expected to get a check engine light and I did. I have a OBD2 ecu, will a OBD1 ecu turn the light off? I have a 97 GS-R and was wondering what ecu to get.
Old Dec 28, 2004 | 02:54 PM
Patch's Avatar
Default Re: After my straight pipe install... (85mm LS VTEC)
Yes, an OBD1 ecu will solve your problem. Look for a P72 ecu out of a 94-95 GSR. Don't forget the conversion harness.
Old Dec 28, 2004 | 04:28 PM
Padawan's Avatar
Darth ModerVader
If the only reason you're getting the ECU is to eliminate the CEL, I definitely wouldn't bother. It won't cause any problems leaving it as-is.
Old Dec 28, 2004 | 07:07 PM
B-B-K's Avatar
Default Re: After my straight pipe install... (Padawan)
Ya, just put a strip of electrical tape over the light so you wont have to look at the light.
Me, personally....I would try get rid of the light just in case something serious happens with your motor you wont know if the light is always on.
Just me....
Old Dec 28, 2004 | 10:05 PM
DavidT or VajT's Avatar
Default Re: After my straight pipe install... (B-B-K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-B-K &raquo;</TD></TR><TR><TD CLASS="quote">Ya, just put a strip of electrical tape over the light so you wont have to look at the light.
Just me....</TD></TR></TABLE>
Or take the bulb out of the cluster
Old Dec 29, 2004 | 03:44 AM
BlkSIvic's Avatar
o2 simulator
Old Dec 29, 2004 | 08:34 AM
Default Re: After my straight pipe install... (BlkSIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkSIvic &raquo;</TD></TR><TR><TD CLASS="quote">o2 simulator </TD></TR></TABLE>
Where can someone get their hands on one of those?
Old Dec 29, 2004 | 01:13 PM
dcvt16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85mm LS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Where can someone get their hands on one of those?</TD></TR></TABLE>
http://www.mkiv.com/techarticl...lator/
chrisbb6
Aug 12, 2011 02:13 AM
1320king
Jul 22, 2007 12:32 PM
Cameron60
Jan 16, 2007 08:03 PM
Defiant1999
Jun 3, 2003 10:41 AM
Blaze45
Jul 13, 2002 05:22 PM
