WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR
Old Dec 28, 2004 | 07:50 AM
JnyStylz's Avatar
Default Whats the difference between 92-93 ls motor and a 94+ ls motor
i have a 95 eg, I think that im leaning twards doing an ls swap. then turbo down the road instead of turbo charging my 1.5L. My question is, Is there a major performance or instalation difference between the 92-93 ls motor and the 94+ ls motor?? either way i plan to use a 94+ B series tranny. I would greatly appreciate all of your help. Thanks
Modified by JnyStylz at 12:02 PM 12/28/2004
Old Dec 28, 2004 | 07:52 AM
Targa250R's Avatar
be professional
Default Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (JnyStylz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JnyStylz &raquo;</TD></TR><TR><TD CLASS="quote">My question is, Is there a major performance or instalation difference between the 92-93 ls motor and the 94+ ls motor??</TD></TR></TABLE>
Not really. Mounts are the only significant difference.
Old Dec 28, 2004 | 07:53 AM
Soccerking3000's Avatar
first of all, dont make titles in all caps, that is frowned upon. And for the motor i dont think there is much of a difference, just make sure you get a b18b not b18a
Old Dec 28, 2004 | 07:55 AM
Targa250R's Avatar
be professional
Default Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you get a b18b not b18a</TD></TR></TABLE>
'92-93 engines are stamped B18A1. '94-01 engines are stamped B18B1.
Old Dec 28, 2004 | 08:01 AM
Default Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (Targa250R)
thats what i thought, from what i hear the b18b is a better motor...
Old Dec 28, 2004 | 08:03 AM
JnyStylz's Avatar
Default Re: Whats the difference between 92-93 ls motor and a 94+ ls motor (JnyStylz)
Sorry about the CAPS. So do I need a mount kit to put the 92-93 ls motor in my 95 eg
Old Dec 28, 2004 | 08:04 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought, from what i hear the b18b is a better motor...</TD></TR></TABLE>
The '92-93 B18A1 is pretty much identical to the B18B1.
The '90-91 B18A1 is the one with slight differences.
Old Dec 28, 2004 | 08:05 AM
ahh thanks for the info, didnt know
Old Dec 28, 2004 | 08:32 AM
squirrel's Avatar
I'm not 100% positive but...
'90-'91 B18A OBD0 rated at ~130hp
'92-'93 B18A OBDI rated at ~140hp (I think it had a longer duration intake cam)
'94-'95 B18B same as '92-'93, but with a better intake manifold
'96+ B18B OBDII and I think It came with knock sensing
someone correct me if I'm wrong
Old Dec 28, 2004 | 08:34 AM
OnePointFive's Avatar
overrated.
Default Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (squirrel)
if you get a 92-93, make sure you get the driver's side mount bracket from a 94+ motor.
Old Dec 28, 2004 | 09:24 AM
JnyStylz's Avatar
Default Re: WHATS THE DIFFERENCE BETWEEN 92-93 LS MOTOR AND A 94+ LS MOTOR (OnePointFive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointFive &raquo;</TD></TR><TR><TD CLASS="quote">if you get a 92-93, make sure you get the driver's side mount bracket from a 94+ motor.</TD></TR></TABLE>
is that the only thing that i need in order to do the swap
Old Dec 28, 2004 | 09:33 AM
turbotime's Avatar
im swapping a 93 b17a1 and i bought all 94+ mounts, a 94+ hydro tranny and 94+ axles
Old Dec 28, 2004 | 10:48 AM
dohcdelsol93's Avatar
Default Re: (turbotime)
about 2 horsepower.
Fighterinsnatch
Sep 22, 2008 08:44 AM
my hatch
Nov 27, 2005 03:21 PM
WhoNeedsBoost
Apr 24, 2002 10:29 AM
