swap engine wiring help
well i got a b18a1 and i what a digram so i am convert my 95 civic to the new engine wiring i what to install the engine by myself and i need to know how to convert it my self
i sorry i havent searched but i am in a little bit of a rush so sorry
i have the wire harness for the new engine that came with it and the ecu to but now i am what to install it in a 95 civic dx and i dont know **** on wiring.
plez help
thanks
nurvcom
plez help
thanks
nurvcom
I dont have one, so heres a free bump for you.
Just so you know it is midnight in Cali, so alot later across the US so alot of people are sleeping. I suggest bumping your thread in the morning and see what you get by noon.
you never said if the engine was obd I or obd 0. I would recomend switching everthing to obd I if it is the obd O. then just use your stock wiring harness. I'll give you a list of all you need if you want to do the conversion.
well on the new engine the plugs are clear and on my civic they are grey i have no clue what are what i i am noob on install a swap engine so help i would like much
thanks
thanks
well i got the engine out of a 94 intgra and it has everything with that engine i have the ecu and the wireharness but i need info on how to conver the plug to fit my plugs for my 95 civic dx stock one i replaced the ecu wire harness now i am needing the rest of the hard harness conveted i need some thing that tell where each wire go's so i can ether make a pluge for it or just wire it strate
thank
i am noob at putting engine in i only know a few things
i what to do it my self to learn more about my car and ****
thank
