5 wire o2 sensor converted into 4 wire o2sensor
Old Dec 27, 2004 | 09:34 PM
dropd4door's Avatar
Default 5 wire o2 sensor converted into 4 wire o2sensor
ok i understand how ti change over as the site states http://info.honda-tech.com/ind...ensor but instead of going to a junkyard and finding a 4 wire plug and re wiring that can i just hard wire the 4 wires to the o2 sensor instead of running it through the plug???
Old Dec 27, 2004 | 10:05 PM
eda6's Avatar
Default Re: 5 wire o2 sensor converted into 4 wire o2sensor (dropd4door)
You could do that.
You could depin one wire from your o2 sensor harness and solder the 5 wire plug onto the 4 wire o2 sensor. Saves you a trip to the junkyard and keeps the quick disconnect fitting.
I'd just get a four wire o2 sensor and do it right.
Old Dec 27, 2004 | 10:22 PM
dropd4door's Avatar
Default Re: 5 wire o2 sensor converted into 4 wire o2sensor (eda6)
im talking about cuting the plug off totally i dont plan on dis connectin the o2 sensor anyway, i jus wanna get this **** running right already...
efking1985
Feb 12, 2007 08:31 AM
xgsrturbox
Apr 8, 2006 11:01 PM
93Bubble
Aug 20, 2005 09:17 AM
dropd4door
Dec 27, 2004 09:53 PM
