d15b valve cover gasket
Old Dec 27, 2004 | 08:50 PM
snoochtodanooch's Avatar
Default d15b valve cover gasket
anyone know what gasket to use. I bought the z6 gasket and it didn't work. I am guessing i should try the VX, but i really don't know. Any info on this would help.
oo by the way in case your wondering the z6 was jus a little toooo long.
Old Dec 27, 2004 | 11:22 PM
Redline130's Avatar
Default Re: d15b valve cover gasket (snoochtodanooch)
That's wierd, I thought that the heads were the same, physically.
Old Dec 28, 2004 | 12:36 AM
whizdumb's Avatar
Default Re: d15b valve cover gasket (Redline130)
Yeah I thought z6 would work too... we really need to get a list going of part #s that are interchangeable for the d15b since there is so little info on them.
I guess take the gasket into the dealership or autozone and try to measure it against another one.
If you do find out which one it is, let us know too.
Good luck.
Old Dec 28, 2004 | 06:13 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">
oo by the way in case your wondering the z6 was jus a little toooo long. </TD></TR></TABLE>
Did you buy aftermarket?
The Z6 gasket is the right one. I am 100% sure of that.
Old Dec 28, 2004 | 09:17 AM
Default Re: d15b valve cover gasket (Jim Truett)
i think that felpro packaged the gasket wrong, i got another gasket today and it is good. d15b7 is what the back says.
Old Dec 28, 2004 | 01:43 PM
second gasket was an inch and a half too long. I just reused the old one with some RTV around those trouble spots. i am not sure what gasket to use, i will try another z6 gasket some time down the line, not for now though.
Old Dec 28, 2004 | 06:34 PM
Jim Truett's Avatar
If you get an OEM D16Z6 gasket it will work, provided you are talking about a SOHC VTEC D15B. I guarantee it.
Old Dec 29, 2004 | 05:11 AM
ok, i will do so in the spring, don't have any time now, and I most definently need to get the engine into the car. can't believe that this **** got fucked up 3xs...
JDM_SOHC
12
Dec 24, 2007 06:37 PM
nappyroots827
Aug 3, 2006 10:19 AM
1991civicsi
Mar 24, 2006 08:03 PM
1gEF-8
Jun 30, 2005 06:19 AM
firstgenrex
Oct 9, 2003 02:55 PM
