what makes more power ls vtec- cr vtec
a cr/vtec will make more torque simply because it has more displacement. but it also depends on the pistons and what head you use on how you set up the ls/vtec. you could stroke the hell out of it and make just as much as a stock bottom end b20 with a vtec head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 »</TD></TR><TR><TD CLASS="quote">a cr/vtec will make more torque simply because it has more displacement. but it also depends on the pistons and what head you use on how you set up the ls/vtec. you could stroke the hell out of it and make just as much as a stock bottom end b20 with a vtec head.</TD></TR></TABLE>
<FONT COLOR="royalblue"> B20 & B18A/B have the same stroke, the diffrence is the bore size. B20B/Z has a 84.5mm Bore & the B18A/B has a 81.5mm bore. CRVTEC's have been know make good power w/ stock pistons and upgraded cams & tuning. I have seen some hit 13.0 & 12.8 w/ stock bottom ends. </FONT>
