Ok u guys want a good laugh
OK im doing this on a $1000 bet i have a 88 crx 1.5 stock I have to use a saab 900 turbo on it and make more then 150 hp out of it nad it has to run all season if you guys can help me out with some tips i can build the rest.
Just do the DPFI swap to MPFI like others have suggested. Maybe take some time and remove your head and look around to make sure that somthing other than the Turbo set up wont cause you any problems. Check all your wires and sensors and then install the turbo. It should work all season but I doubt that you will be getting those numbers from a D15. You might have to get more **** like Intake and Exaust to get to that HP number.
So what you must ask yourself is all this money, time, and effort worth the $1000?
CRX Forum
CRX Forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum »</TD></TR><TR><TD CLASS="quote">Just do the DPFI swap to MPFI like others have suggested. Maybe take some time and remove your head and look around to make sure that somthing other than the Turbo set up wont cause you any problems. Check all your wires and sensors and then install the turbo. It should work all season but I doubt that you will be getting those numbers from a D15. You might have to get more **** like Intake and Exaust to get to that HP number.
CRX Forum</TD></TR></TABLE>
he needs to get an intake on his turbo setup?
dpfi= dual point fuel injection, 2 injectors, throttle body sits like a carbuerator on the intake manifold.
mpfi= multi point fuel injection, one injector for each cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">dpfi= dual point fuel injection, 2 injectors, throttle body sits like a carbuerator on the intake manifold.
mpfi= multi point fuel injection, one injector for each cylinder.</TD></TR></TABLE>
thanks for clearing that up. Are there pic of the difference? thanks
the price that its going to be to achieve 150hp on a dyno. will cost you $1,000 to 1,5000 reliably. so basicallt you get what you spent back HOPEFULLY.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanb »</TD></TR><TR><TD CLASS="quote">
he needs to get an intake on his turbo setup? </TD></TR></TABLE>
No. I wes saying that I dont think that he will be able to get 150HP from a D15 turbo alone. Getting other things like I/H/E might get him closer to the number he is wanting to get.
CRX Forum
CRX Forum
when u go turbo, u dont use an intake or headers anymore...
