Looking for the needle in the hay stack...
Old Dec 27, 2004 | 07:18 PM
ralphie14's Avatar
Default Looking for the needle in the hay stack...
I have a 2000 front end on a 93 si hatch. So I bought some fog lights cheap from a guy I know since I really like the looks of the EK fogs well it dawned on me that all of the wiring is wrong on the wire harnesses that I have now since I still have original EG wiring throughout the car. So going on a long shot here does any one have or know someone that has the complete wiring harnesses for EG fog lights? If so can you PM me their info or try to IM me sometime. Thanks.
-Mike
Old Dec 27, 2004 | 07:22 PM
eK9aT10pSi's Avatar
Default Re: Looking for the needle in the hay stack... (ralphie14)
hopefully you can find it used because honda doesnt sell them seperately.
Old Dec 27, 2004 | 07:23 PM
civictildeath's Avatar
Default Re: Looking for the needle in the hay stack... (eK9aT10pSi)
try classified forum maybe
Old Dec 27, 2004 | 07:28 PM
ralphie14's Avatar
Default Re: Looking for the needle in the hay stack... (civictildeath)
Yeah I have been looking through there too and yeah I know they are not sold seperatly that is the needle in the hay stack part haha. My only hope is someone that is not using thier harnesses for some god knows why reason or someone that has broken fogs and good harnesses.
Old Dec 27, 2004 | 07:29 PM
call some junkyards and good luck
Old Dec 27, 2004 | 07:38 PM
ralphie14's Avatar
thanks I found what I needed in the classifieds but I was too late it was already sold! Damn! So I am still looking.
Old Dec 28, 2004 | 04:57 AM
ralphie14's Avatar
Bump for anohter go at it.
Old Dec 28, 2004 | 06:13 AM
mike1114's Avatar
Just make your own harness or go to Vatozone and buy a fog light wiring kit. It is the same thing as what you get fron honda, just without the cool factory looking light switch.
I made my own harness, not too hard, power, ground, alternate power, 5 pole relay, your pretty much done.
Old Dec 28, 2004 | 02:06 PM
ralphie14's Avatar
Default Re: Looking for the needle in the hay stack... (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Just make your own harness or go to Vatozone and buy a fog light wiring kit. It is the same thing as what you get fron honda, just without the cool factory looking light switch.
I made my own harness, not too hard, power, ground, alternate power, 5 pole relay, your pretty much done.</TD></TR></TABLE>
So these harnesses are exactly like the OEM ones? Or will they at least have all the same connectors as the OEM ones? I would rather not make my own I am not that electrically inclined really I would rather just have to connect plugs.
civic_hb_4-life
May 27, 2010 10:38 AM
BILLisCHILL
Feb 27, 2010 07:54 AM
BILLisCHILL
Feb 26, 2010 10:47 PM
