stock gsr compression ?
Old Dec 27, 2004 | 06:24 PM
Humble1's Avatar
Default stock gsr compression ?
just purchased a 94 jdm gsr b18c swap in a 94 civic coupe and did a compression test, cold temp. results as follow. are these results normal or is it time for a rebuild. never did a leakdown test cuz i dont have the tools for that. ive search already but found no answer. reason i ask cuz, i noticed a lack of power. mods are cai/header/exhaust/msd blaster coil. at this point car runs very rich and did a baseline dyno only to find with 150 whp 114 trq. can any one chime in those who got stock gsr with bolt on mods. im kinda concerned performance wise tia for all reply
cylinder 1) 190
2) 190
3) 185
4) 185
Old Dec 27, 2004 | 07:40 PM
Mike K's Avatar
Default Re: stock gsr compression ? (Humble1)
compression seems about right. get the a/f tuned properly.
Old Dec 27, 2004 | 10:22 PM
sheepey's Avatar
thast the hp GSR motors make with all the bolt ons. Its avg. I made 160 with intake,header,exhaust, vafc2 and fpr. Tuned
Old Dec 30, 2004 | 10:39 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble1 &raquo;</TD></TR><TR><TD CLASS="quote">can any one chime in those who got stock gsr with bolt on mods. im kinda concerned performance wise tia for all reply
cylinder 1) 190
2) 190
3) 185
4) 185</TD></TR></TABLE>
those are some good comp #'s here is the link to my bolt-ons gsr that you can compare. If you stated the car is running very rich, then it will actually hurt the performance since injecting excessive fuel will have less to chance atomized properly. Result, loss in power. Someone said earlier, get the a/f tune out. Btw, you should get ur car to a shop and do the leak-down test, compression didn't tell you whole lot about the condition or the car
dyno's link
https://honda-tech.com/zerothread?id=1094753
Old Dec 30, 2004 | 11:06 PM
ferio 95's Avatar
Default Re: stock gsr compression ? (yeegsr)
actually those numbers suck ***. what kinda mileage does your motor have? anything under 200 isnt really healthy for a gsr. mine cranked out 230 across the board before i rebuilt it. and cranks 240 now with the itr pistons in it
Old Dec 30, 2004 | 11:52 PM
Humble1's Avatar
Default Re: stock gsr compression ? (ferio 95)
as stated in my first post , those result were done on cold temp not at operating temp. i know if it was tested at operating temp i would get higher results. as far as mileage, i would have no clue what mileage its currently on since i bought them from password jdm as a front clip.
Old Dec 31, 2004 | 12:33 AM
ferio 95's Avatar
maybe since your unning rich your burning valves. your rings could possibly be worn
Old Dec 31, 2004 | 12:35 AM
ferio 95's Avatar
i never knew that operating temp made a difference. everytime i tested my cylinder compression the motor was cold
Old Jan 8, 2005 | 02:26 AM
yeegsr's Avatar
bump for more info
Old Jan 24, 2006 | 06:03 PM
Vera's Avatar
helms says from like 180 to 230 is good
mine came out around 185 to 190...
its more the #s being closer to each rather than how high they are
of course if a # is way out of range then you know something is up
B20 vtec DC2
Oct 15, 2006 06:28 PM
98h22
Feb 26, 2006 06:50 PM
MikeTV
Apr 19, 2005 06:27 AM
sshaikh01
Mar 22, 2005 10:35 AM
