Feeler gauge placement?
Old Dec 27, 2004 | 04:54 PM
silentblackhat's Avatar
Default Feeler gauge placement?
DELETE
Never mind i figured it out. I found my AUtomotive Fundamentals book and it shows me with all the pics of what i needed. thanks for the help tho
Modified by silentblackhat at 6:34 PM 12/27/2004
Old Dec 27, 2004 | 04:59 PM
jlacoy82's Avatar
71.192.16.183
It even shows you in the helms manual..........
Place it between the cam lobe and valve, with that particular piston set at TDC.
Old Dec 27, 2004 | 05:03 PM
Default Re: (jlacoy82)
does anyone have a pic with it upclose? what exactly is the cam lobe and the valve look like. im jsut trying to learn. i have the engine at TDC for poston #1 allready
Old Dec 27, 2004 | 05:36 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">It even shows you in the helms manual..........
Place it between the cam lobe and valve, with that particular piston set at TDC. </TD></TR></TABLE>
Do you mean between the cam lobe and the rocker arm?
One side of the rocker arm rides on the cam and the other side pushes down on the top of the valve.
When I personally do a valve adjustment on a sohc, I put the feeler guage between the the rocker arm and the valve(where the adjusting nut is), just because its easier to get to.
Also, to save a little time, you can use this proceedure to adjust the valves.
With #1 at TDC you can adjust all the valves on cyl #1, the intake valves on cyl #2 and the exhaust valves on cyl #3.
Then rotate the crank 360 degrees and line the white mark up again. Now cly #4 is at TDC.
Adjust all the valves on cyl #4 and then intake valves on cyl#3 and exhaust valves on cyl#2.
It speeds things up quite a bit.
Have fun.
Old Dec 27, 2004 | 06:16 PM
Default Re: (Slopoke)
crap! that would have helped alot. im almost done tho,. thanks for the info. ill keep that in mind when i do it next to my car
Old Dec 27, 2004 | 06:49 PM
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
Have fun.
Yeah thats what I meant
And thats a damned good trick, I'll have to use that.
vtec.dc2
Nov 29, 2006 01:58 AM
SpoogenJay
Aug 9, 2003 01:37 PM
216.226.142.95:27016
Jul 4, 2003 10:23 AM
White Lightnin
Mar 10, 2003 09:30 AM
Chubz
Jul 8, 2002 12:31 PM
