Another no starting car!!!
i just changed the battery and it turns over but doesnt start and it doesnt sound like it wants to fire, the sound of the engine doesnt change compared to a regular engine when you crank it the sound pitch goes up and down, any ideas?
make sure your battery terminals are screwed down tightly.
take apart your starter and have it tested at a local autozone.
take apart your distributor and check your ignition coil. see if it has burnt marks or if it smells funny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce »</TD></TR><TR><TD CLASS="quote">did anything weird happen with the car? over heat or something?</TD></TR></TABLE>
nothing wierd happened, started it yesterday, let it run for about a half hour, no over heating
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $300lude »</TD></TR><TR><TD CLASS="quote">Kinda sounds like your starter isn't engaging the flywheel from your description. Pull a spark plug and put your hand over the hole and feel for compression.</TD></TR></TABLE>
If he is getting spark, then the distributor is turning, so the engine has to be cranking.
If the starter wasnt enguaging the flywheel, you would know it. It sounds nothing like the engine turning over. It is an awful high pitch screetching sound.
If you are 100% sure you are getting fuel and spark, I would check your cam timing and then do a compression check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">i dont know, i got the engien adn swapped it in so i guess the person before already had it bent</TD></TR></TABLE>
bent valve is not that bad just as long as it didn't mess up anything else
is it a d series?
is it a d series?
junya16
Mar 1, 2003 05:41 PM
