Full ABS removal - Has anyone done this?
I am wanting to know if anyone with a G3 has actually removed ALL of the abs lines and boxes, etc.
I have removed the abs control module, and fuse box, but haven't taken the time to re-run all the lines, and all that nonsense.
Has anyone in here obsessive compulsive enough to have already done it, and how do you rate the difficulty? I really think it would clean up the engine bay, and it might amount to 2-3 lbs of weight reduction (I take weight reduction VERY seriously)
LMK - and thank you in advance for any wisdom you may be able to share.
Youre removing it for weight reduction? Are you serious? You wont get any gains in performance from the miniscule reduction in weight, and your car will perform worse under hard braking.
I did this in my Integra.
You need different parts if you car is 94-97 or 98-01.
Here is the thread with the parts you need and some pictures.
http://m24x.zeroforum.com/zerothread?id=995
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">I did this in my Integra.
http://m24x.zeroforum.com/zerothread?id=995</TD></TR></TABLE>
any chance in hell that thread can be found or anything? i need this info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource »</TD></TR><TR><TD CLASS="quote">I am wanting to know if anyone with a G3 has actually removed ALL of the abs lines and boxes, etc.
.</TD></TR></TABLE>
so i can take out all the bulky ugly **** and still run the oem lines in my LS?
.</TD></TR></TABLE>
