anyone remove their ABS??
Old Dec 19, 2005 | 06:56 PM
WhoDoYouThink's Avatar
Default anyone remove their ABS??
i have '00 gsr, just curious how much work is involved in removing the ABS and what i need to do.
Old Dec 19, 2005 | 07:23 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: anyone remove their ABS?? (2000turbogsr)
if this a daily driver i see NO need to do this at all, your not gonna see much weight decrease. And if your going AutoX then its going to get hard to get use to your car without ABS, since you've been driving it this whole time with it.
Old Dec 19, 2005 | 07:45 PM
Default Re: anyone remove their ABS?? (00IntegrAllmotoR)
i know it would take getting used to, however i HATE all the clutter in engine bay caused by the hard lines and ABS unit. I have heard I can switch lines from a older RS Integra which doesnt have ABS. someone let me know if this is true and how much work is involved in doing so. Please don't tell me i won't like it, because I have driven plenty of cars w/o ABS and I have no problem with it.
Old Dec 19, 2005 | 10:28 PM
teg racer 877's Avatar
I want to do the same thing on my 95 gsr, my abs unit is broken so I want to convert to no abs, looks hard though, with all those lines everywhere, someone tell us how to do it.
Old Dec 19, 2005 | 10:43 PM
Default Re: anyone remove their ABS?? (teg racer 877)
for real. it looks like some major work ahead of us man!
Old Dec 24, 2005 | 03:12 PM
aaroboost's Avatar
yes yes me too. mine is broke and i hear its real pricey to fix. some help?
Old Dec 24, 2005 | 03:25 PM
t0ekn3e's Avatar
you get rs lines and an em1 prop vavle i belive and swapit out. pretty straitfoward cost about 100 to do to my friends 01 gsr took us about 2 hours i think.
Old Dec 24, 2005 | 06:02 PM
aaroboost's Avatar
Default Re: (t0ekn3e)
what is a prop valve, and is a em1 a 01 to 05 civic?
Old Dec 24, 2005 | 06:12 PM
TurboGS-R's Avatar
Default Re: (aaro890)
I heard that it was a tough job, so I haven't done it yet. I hope this turns out to be a great informational thread because I really want to do this too.
Old Dec 24, 2005 | 06:13 PM
TurboGS-R's Avatar
Default Re: (TurboGS-R)
Also this thread reminds me of when my GS-R was stock and my uncle drove it occasionally to work. One of his coworkers told him that my car was "fast because of all those lines" (referring to the ABS unit).
Old Dec 24, 2005 | 06:24 PM
old_school_dohcvtec's Avatar
how did your guys ABS stop working?
Old Dec 24, 2005 | 06:40 PM
Default Re: anyone remove their ABS?? (oldschooldohcer)
I dont know how the abs stops working, but my car sat in my front yard without a motor for like 2 years so I guess thats why it doesnt work, I like it with no abs and I really want to take it out, please elaborate on how the removal is done and thanks for the info so far.
Old Dec 24, 2005 | 08:02 PM
not so JDM Dan's Avatar
its pretty simple you get everything from a rs teg master cylinder prop valve and the master cylinder to prop valve lines and the prop valve to front brake lines the rear will bolt up fine. with the full system removed (abs unit, abs computer, abs sub-harness, abs fuse box and relays plus all the lines) you will lose almost 30 lbs. i havent weighed all my stuff but its a good amount. i hated the abs in my car plus it looks like ****
Old Dec 24, 2005 | 08:04 PM
t0ekn3e's Avatar
1. buy your year rs brake lines.
2. buy ek prop valve.
3. follow the line and replace them, and replace prop valve.
4. bleed your brake system.
i think all that information is correct ill have to verify that but we did it to my friends gsr and here was the outcome. the lines get annoying to fish out and fish back in.
Modified by t0ekn3e at 4:04 AM 12/25/2005
Old Dec 24, 2005 | 08:14 PM
t0ekn3e's Avatar
better pic
Old Dec 24, 2005 | 10:20 PM
magicaltrout's Avatar
that is hella clean.
Old Dec 24, 2005 | 10:33 PM
KOALA YUMMIES's Avatar
Default Re: anyone remove their ABS?? (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">1. buy your year rs brake lines.
3. bleed your brake system.
4. follow the line and replace them, and replace prop valve.
5. add brake fluid.
i think all that information is correct ill have to verify that but we did it to my friends gsr and here was the outcome. </TD></TR></TABLE>
Um, why the heck would you bleed it before you replaced the lines? Youd want to do that after...
Old Dec 25, 2005 | 12:04 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: anyone remove their ABS?? (KOALA YUMMIES)
I am haveing my ABS removed as well sometime next year. I am in the same boat as the rest of you, I dont have a clue in hell as how to do this so a friend of mine who is a Hondatech at Honda is doing it for me. Hope everything goes well with that. And I agree I think the engine bay looks so much cleaner wiht out the ABS. Good luck.
Old Dec 25, 2005 | 03:03 AM
t0ekn3e's Avatar
brain kinda turned off since no more school.
Old Dec 25, 2005 | 07:17 AM
RenzoDaPlayboi's Avatar
better pic</TD></TR></TABLE>
Beautiful
Old Dec 25, 2005 | 11:51 AM
ShinsenTuner's Avatar
No Jodas
IMO, function over form. I'd rather have ABS instead of taking it out just to have a "shaved" engine bay. Show car, sure it's not going to drive anyway, on a street car where you barely pop your hood for anyone. Not very worth it at all.
Old Dec 25, 2005 | 01:34 PM
Default Re: (ShinsenTuner)
^^ I agree, that guy can't even clean his windsheild while driving, but the factory hood prop wasnt enough so he added two gas filled ones
Old Dec 25, 2005 | 01:41 PM
Naruto's Avatar
Default Re:
Eh....I'm having my ABS removed due to issues with it. I actually tallied up the total cost to repair the damned thing ( 2 sensors and the modulator itself ) versus removing it. Removing it was way cheaper Though....I do agree partially about that shaved engine bay comment. Some things....I just can't do without ( like power steering & window washers ).
Old Dec 25, 2005 | 01:59 PM
t0ekn3e's Avatar
that car not mines, but it is not a daily driver thats why. i wouldnt remove that stuff on my own car.
Old Dec 25, 2005 | 03:04 PM
migs's Avatar
https://honda-tech.com/zerothread?id=1160671
