when i floor it,it bogs down any help?!!!!
Old Dec 27, 2004 | 11:49 AM
dobbs1027's Avatar
Default when i floor it,it bogs down any help?!!!!
ihave a 93 delsol with a jdm b26a2 and just today when i floor the car it will bog down does anyone no whats up or what i should look for?
Old Dec 27, 2004 | 11:50 AM
dobbs1027's Avatar
Default Re: when i floor it,it bogs down any help?!!!! (dobbs1027)
sorry its ab16a2
Lee_Delso's Avatar
Timing or fuel problems?
Old Dec 27, 2004 | 12:05 PM
IVI's Avatar
IVI
Default Re: when i floor it,it bogs down any help?!!!! (Lee_Delso)
when was a tune up last done?
it could be a weak spark, bad fuel delivery.
check the plugs, what condition are they in?
cap & rotor?
fuel injectors could be clogging.
Old Dec 27, 2004 | 12:08 PM
JDMlyfestyle's Avatar
Thowing any CEL... have u worked on the car prior to this happening?
Check all of your ground connections under the hood to be sure they arent loose.
Old Dec 27, 2004 | 12:36 PM
NonovUrbizniz's Avatar
Loved
Almost definately a fuel problem..
When's the last time you changed the fuel filter?
What engine did the car come with?
Could be as simple as the fuel pump not being able to run to the capacity of the new engine...
Do you run the tank dry a lot? or do you always keep it over half tank?
Old Dec 27, 2004 | 12:44 PM
BDogggUT34's Avatar
Default Re: when i floor it,it bogs down any help?!!!! (NonovUrbizniz)
i agree with the above from experience, i just had my LS swapped and the car had been sitting for about 6 months with a half tank. Ran good at first then completely ran like crap, changed fuel filter and filled her up with a tank of premium and all is perfect!!
Old Dec 28, 2004 | 03:17 PM
dobbs1027's Avatar
Default Re: when i floor it,it bogs down any help?!!!! (BDogggUT34)
thanks i live in fl and we just got alot of rain some how ssome got to the spark plugs it all good now thanx
WestTnhondaguy
11
Apr 17, 2015 08:06 PM
89b20crx
Mar 8, 2011 09:54 AM
blackhatchy
Dec 4, 2003 05:20 PM
EL'ation
Jun 5, 2003 08:06 AM
Krayzielix
Feb 2, 2003 04:12 PM
