BLACK SMOG PROBLEM, NEED SUGGESTIONS!!!
Old Jan 6, 2002 | 05:09 PM
NZcrx88's Avatar
Default BLACK SMOG PROBLEM, NEED SUGGESTIONS!!!
This is 88CRX. when I start engine in the morning, black smog continues for about 2 or 3 minutes and finishes when engine temperature is over 40, the car runs well all the day then. It would be grateful if you may have any suggestions!!
Old Jan 7, 2002 | 01:46 AM
brad.'s Avatar
Default Re: BLACK SMOG PROBLEM, NEED SUGGESTIONS!!! (NZcrx88)
hmmm...how much smog are you getting out of there?
like huge clouds?!?
Old Jan 7, 2002 | 01:58 AM
balistic CRX's Avatar
Default Re: BLACK SMOG PROBLEM, NEED SUGGESTIONS!!! ([626]JDM-b16a-EF9)
maybe you are burning oil. check your spark plugs and see if there is any oil on it. thats what i think.
Old Jan 7, 2002 | 12:07 PM
NZcrx88's Avatar
Thanks for ur suggestion. the smog is not like clouds and it goes out when the engine gets hot enough, otherwise everything is not bad.
Old Jan 7, 2002 | 12:10 PM
NZcrx88's Avatar
Default Re: BLACK SMOG PROBLEM, NEED SUGGESTIONS!!! (balistic CRX)
Thanks for ur suggestion! i try to remove the plugs but they r so tight that i can not do it myself, i may go to the service station. Many thanks!
redDAinteg
Sep 13, 2012 08:14 PM
SimbaDogg
May 23, 2003 01:00 PM
YellowCivic95
Apr 24, 2002 08:54 AM
TypeRInNeed
Jan 6, 2002 10:07 PM
