car is shaking badly when i accelerate, what can it be?
Old Dec 27, 2004 | 08:27 AM
mattL's Avatar
Default car is shaking badly when i accelerate, what can it be?
Hey, i've got ideas on what it could be but i just want to get your feedback before i start replacing parts. symptoms are basically that the car shakes but only when accelerating and mostly in 2nd,3rd and 4th gear between 3-5k rpm. I dont feel it in the steering wheel only in the car and i doesnt do it when going at a steady speed or when coasting out of gear. also the steering wheel does not shake at all so i dont think my rim is bent or it has anything to do with the wheel balance. and both my axles are new. what do you think? TIA
Old Dec 27, 2004 | 08:29 AM
MassScene's Avatar
Default Re: car is shaking badly when i accelerate, what can it be? (mattL)
ima have to say motor mounts
Old Dec 27, 2004 | 08:55 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattL &raquo;</TD></TR><TR><TD CLASS="quote">Hey, i've got ideas on what it could be but i just want to get your feedback before i start replacing parts. symptoms are basically that the car shakes but only when accelerating and mostly in 2nd,3rd and 4th gear between 3-5k rpm. I dont feel it in the steering wheel only in the car and i doesnt do it when going at a steady speed or when coasting out of gear. also the steering wheel does not shake at all so i dont think my rim is bent or it has anything to do with the wheel balance. and both my axles are new. what do you think? TIA</TD></TR></TABLE>
bump
i have the same problem but its not always shaking, its on and off. been to the shop but did not fix the problem need to go back tom to the shop.
Old Dec 27, 2004 | 09:00 AM
3.504's Avatar
Default Re: car is shaking badly when i accelerate, what can it be? (civic91)
just because your axles are new doesn't mean they aren't the problem. i'd say its the inner joint of your axles. it will especially be your axles if they're aftermarkets (autozone or whomevers re-man'd axles). take the axles back on lifetime warrenty and get a new set. if they are brand new honda axles, then you might have a broken belt or some other rim/tire problem. if it where alignment (and usually wheels) you feel it in the steering wheel, and it would increase with speed, not happen under acceleration. my bet is you have re-man'd axles and they aren't that great, just get another set, they're free.
Old Dec 27, 2004 | 09:06 AM
greaseball's Avatar
Default Re: car is shaking badly when i accelerate, what can it be? (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">just because your axles are new doesn't mean they aren't the problem. i'd say its the inner joint of your axles. it will especially be your axles if they're aftermarkets (autozone or whomevers re-man'd axles). take the axles back on lifetime warrenty and get a new set. if they are brand new honda axles, then you might have a broken belt or some other rim/tire problem. if it where alignment (and usually wheels) you feel it in the steering wheel, and it would increase with speed, not happen under acceleration. my bet is you have re-man'd axles and they aren't that great, just get another set, they're free.</TD></TR></TABLE>
what he said is right on! i've encountered this problem numerous times. i have to say EXCHANGE THOSE AXLES.
Old Dec 27, 2004 | 09:18 AM
civic91's Avatar
how can you tell if the inner joint of axle is bad?
Old Dec 27, 2004 | 12:15 PM
mattL's Avatar
Default Re: car is shaking badly when i accelerate, what can it be? (greaseball)
Yeah its a possiblity that the axles are bad, all motor mounts were replaced 3 months ago and then i did the axles right after. i thought it might be a tie rod end or the lower control arm ball joint. any chance of that ?
Old Dec 27, 2004 | 12:50 PM
greaseball's Avatar
exchange your axles and your problem should go away.
Old Dec 28, 2004 | 05:04 PM
mikestypeRR's Avatar
i had the same problem last week its the inner joint on your axel .. it went bad.
Old Dec 28, 2004 | 05:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">
how can you tell if the inner joint of axle is bad? </TD></TR></TABLE>
if you have the symptoms described above, that's a telltale sign of bad inner joints.
How do I know? I've been through 4 sets of reman. axles since this past summer before I finally got a decent set that DOESN'T vibrate.
hmtcrxsir
Nov 11, 2007 11:14 AM
Turbo Squid
Aug 15, 2005 07:08 PM
jaycetan
17
Mar 26, 2005 11:19 AM
Teknic73
Oct 26, 2004 06:32 PM
devilpuppy
Jul 10, 2004 08:54 PM
