Need help, car is throwing cel 54
Old Dec 27, 2004 | 06:43 AM
Buktheng's Avatar
Default Need help, car is throwing cel 54
Ok, I just changed the ecu in my car back to a p72. I originally had a p28 ecu w/ an obd2 to obd1 conversion harness. So when I put the p72 back in, it gave me an engine checklight code 54 CKF - crank fluctuation sensor. I know that the p28 doesn't mean the sensor hooked up so where exactly is this sensor so I can hook it back up? Can anybody take pics to show me?
Old Dec 27, 2004 | 08:07 AM
Buktheng's Avatar
Ok, where does the crank fluctuation sensor plug into? I think I found the plug and its unplugged but i can't find any spot to plug it in.
Old Dec 27, 2004 | 08:20 AM
3.504's Avatar
Default Re: (Khoifather)
i'm not too good w/ obd2 stuff, so excuse me, but crank sensors are normally magnetic (or hall effect) sensors located on the crank pulley or in the distributor. check in those too spots, if all else fails, call a dealer and ask where its located.
jonathan13
Nov 18, 2010 02:04 PM
KING PIN
Apr 30, 2007 07:03 AM
blowbyu24
Jan 12, 2007 10:54 PM
slo97coupe
15
Mar 19, 2006 07:59 PM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
