LCA???
Who has what type of lower control arms and how do you like them? Does anyone have any comparison's? I am about to install a rear sway and need to replace my LCA's anyways so I figured I shoould just go ahead and get good ones. Any input is helpful, thanks everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kndaqikEG »</TD></TR><TR><TD CLASS="quote">so I figured I shoould just go ahead and get good ones. </TD></TR></TABLE>
Stock w/ mugen bushings. There's no performance benefit to "lightweight" LCA's and I'd be very leary of cheap aluminum suspension arms.
So is that the general consensus, is to use stock type that have the sway bar mounting points and throw in some good bushings? No benefit to the others other than less unsprung weight and the bling factor? Thanks again.
So your going to cut 5-6 pounds from the car. I personaly dont think its worth the money. Plus if your competing in autocrosses your pushing your class way up.
Performance gains will be very minimal if there are any.
Stick with the stock arms and good bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF »</TD></TR><TR><TD CLASS="quote">stock with prothane bushings
ditto in the rear. OEM/OEM in the front.
</TD></TR></TABLE>ditto in the rear. OEM/OEM in the front.
Actually the LCA's are only about 1 pound less. I have the SPC's on mine and thur koo. I only got them as part of a camber correction kit and they are about 1.5in shorter
Since SPC makes considerable amounts of OE suspension stuff I have no worries about thur quality
and then thurs dA MAD TYTE STUNNA BLING SPACTAKULA
That is what I figured. I wasnt sure of I was just missing something or not but I didnt figure that the aluminum ones could be that much lighter. I guess people just get so amazed by shiny things. Thanks again for all the input, I am going to go get my STOCK integra arms and bushings on the way. Later.
