Question about light installation?
Recently I aquired some new Black Halo Projector Headlights for christmas. I need to know the vertical adjustment on them There is a metal peice in the middle of the light and it cuts of letting me only see about 20 feet infront of the car. Keep in mind that when I turn on low beam the are pointing toward the ground, and the hi-beams go normal. Anyone have any suggestions? Thanks.
i bought the same headlights and mine do the same exact thing... you cant see **** past 15 feet infront of you but you turn your high beams on and they are perfect
Are these those Halo light from ebay? Are they just plug in and play Or do you have to use some part from the oem headlight? I was thinking about buying these since my headlight is getting old, does the visibility increase with these light.
Yes. I found out what to do from team-integra.net all you need is a flat head screw driver and you can do it. Park your car about 25 feet back from any wall. NOTE: if the car is to close to the wall you cannot tell it is being adjusted. There are little levers on the back of the light there is a little slot they are very hard to turn so you must use a screw driver. There are 2 main ones they are both metal turn ***** with 4 holes in them the one behind the high beam adjust the lowbeams from top to bottom and the other is for right to left.
i ahve a set of these lights for my integra dont buy them from ebay.... buy them from a a parts dealer around you... if they leak or the halo goes out you cant send them back... i bought mine from a local store and they leaked so they gave me new ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkCrxSi »</TD></TR><TR><TD CLASS="quote">i ahve a set of these lights for my integra dont buy them from ebay.... buy them from a a parts dealer around you... if they leak or the halo goes out you cant send them back... i bought mine from a local store and they leaked so they gave me new ones</TD></TR></TABLE>
Clear silicone before install should help with that.
Yes, those are the exact lights I have on my gs-r. They haven't leaked for me and installation was easy when I installed them I wired them to the main ground wire from the hazard lights. Ive really only had 2 problems with them the right light halos sometimes dont work but I went back and took care of that. Now sometimes when it gets could there is massive condensation in the brights not so much the low beams! Is there something I can do to stop condensation?
junior91hondaac
Jul 13, 2013 09:17 AM
landon.alder
Nov 20, 2009 08:02 AM
m2s4drespecial
Honda Civic (2001 - 2005)
11
Sep 20, 2009 10:25 AM
