warm up time for eg's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed »</TD></TR><TR><TD CLASS="quote">
could this be that i need a new thermostat?</TD></TR></TABLE>
That or you have air bubbles in your coolant system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi »</TD></TR><TR><TD CLASS="quote">
That or you have air bubbles in your coolant system.</TD></TR></TABLE>
im pretty sure that if you have air bubbles, it would cause the car to over heat before it would cause the car to cool down.
my engine is the opposite
it warms up too quick... if its 32 degrees outside, it will literally take 1 minute to warm up to normal temperature... but it never goes higher than that... everyone i had check out my engine said it shouldnt get that hot so quick... but it never overheats... it just warms up to operating temperature real quick... which is nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed »</TD></TR><TR><TD CLASS="quote">like this?
yeah that's it, just remove the #14 bolts and the lower hose and also clean the gasket off and that it. BTW it's common sense to bleed the system but you knew that.
</TD></TR></TABLE>yeah that's it, just remove the #14 bolts and the lower hose and also clean the gasket off and that it. BTW it's common sense to bleed the system but you knew that.
lol...
it's not such a big deal. goto autozone and drop $5 to get a new one.
don't forget the $.50 gasket and $2.50 gasket sealant too. (high temp)
it's not that hard to replace, i'm sure the thermo is around your lower radiator hose.
it should fix your warm up and engine temperature problems.
you're going to have to flush your coolant system when you replace it as well.
good luck.
good luck.
invisible
44
Feb 22, 2008 01:33 PM
fridexter
Nov 20, 2004 02:52 PM
