the time has come....
Old Dec 26, 2004 | 11:46 PM
ATS*Mark's Avatar
OG triple OG
Default the time has come....
well guys i guess the sohc little beast is getting tuned on wed by mase.
ive decided that since the car has a stock head , im going to keep it limited to 20 lbs of boost , so we shall see what the car makes . im very excited to see this car get some numbers under its belt , it goes right to the track after that wish me luck!!!!
Old Dec 26, 2004 | 11:51 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: the time has come.... (Hella_JDM)
I've got a $1 says you won't make more than 200whp.
Old Dec 27, 2004 | 12:21 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: the time has come.... (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">I've got a $1 says you won't make more than 200whp. </TD></TR></TABLE>
Old Dec 27, 2004 | 05:04 AM
FredoSP's Avatar
race gas?
Old Dec 27, 2004 | 07:24 AM
Rod.'s Avatar
Default Re: the time has come.... (FredoSP)
what is the setup?
Old Dec 27, 2004 | 07:39 AM
tgreaves's Avatar
What does 20psi of boost have to do with a stock head.. Its the amount of power your making and the airflow that matters with the head.. Psi is just a number to help you get to your HP goal..
Old Dec 27, 2004 | 08:46 AM
Boosted2K's Avatar
Default Re: the time has come.... (tgreaves)
Good Luck
Make sure you post the dyno chart, I'm curious as to what the powerband of that turbo will look like on the D series
Old Dec 27, 2004 | 09:52 AM
adseguy's Avatar
Ouch, yet so true. lololol
Old Dec 27, 2004 | 10:19 AM
ATS*Mark's Avatar
OG triple OG
lol we shall see.....i hope to double your estimate....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">race gas?</TD></TR></TABLE>
c16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">what is the setup?</TD></TR></TABLE>
gt35e 63 trim . 75mm d16y8 , aebs sleeved , cp pistons pauter rods .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">What does 20psi of boost have to do with a stock head.. Its the amount of power your making and the airflow that matters with the head.. Psi is just a number to help you get to your HP goal..</TD></TR></TABLE>
psi has to do with keeping the hp goal down , i dont want to run more than 20 psi right now . and i know the motor is going to flow for **** with the stock head , so im not going to push it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">Good Luck
Make sure you post the dyno chart, I'm curious as to what the powerband of that turbo will look like on the D series</TD></TR></TABLE>
im sure it will look funny , but its seriously not that bad . the turbo spools pretty nice and it rips at 8 lbs , way harder than 12 on the td04....hondas like the higher rpm band anyway.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
Ouch, yet so true. lololol </TD></TR></TABLE>
interesting , before talking out your *** why dont you get your **** strait.
Old Dec 27, 2004 | 10:28 AM
Quad-Damag's Avatar
mark should make some good power, i just want to see the dyno sheet
1k to 5k 120whp and after 5k u will see a huge jump when that turbo spools, sucks u couldn't get a built head, becuase if u reved to about 8500 im sure u will hit your hp goal.
Old Dec 27, 2004 | 12:42 PM
ATS*Mark's Avatar
OG triple OG
Default Re: the time has come.... (Quad-Damge)
im sure ill get close......the thing will make good power till redline thats for sure.
Old Dec 29, 2004 | 06:45 PM
DefiantGSR's Avatar
what did your car put down!? i'm interested in seeing what a D series can do!
Old Dec 29, 2004 | 07:12 PM
Quad-Damag's Avatar
Default Re: the time has come.... (DefiantGSR)
money on the car had problems and didn't brake over 260whp
BUT PLEASE PROVE ME WRONG!
Old Dec 29, 2004 | 07:20 PM
Boltz's Avatar
Waiting to hear dyno....
Old Dec 29, 2004 | 08:21 PM
TURBO HONDA's Avatar
yeap
Old Dec 29, 2004 | 08:25 PM
USDM 4G VTEC's Avatar
so?!?!?!?!
Old Dec 30, 2004 | 07:42 AM
Default Re: the time has come.... (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">Waiting to hear dyno....</TD></TR></TABLE>
It's Thursday, bitch.
Old Dec 30, 2004 | 09:58 AM
ATS*Mark's Avatar
OG triple OG
we ran into alot of gay problems , the car didnt even get onto the dyno till like 2 am.....modacar stayed till 330 and finally called it quits , boy is that shop ******* awsome i have to add , they were there for like 15 hours tuning all day with mase...
but from one hour of actual tuning i did , i based at 208 199 , then a little tuning at 13 lbs it made 263whp 247 tq.....not bad for stock tb , im and head.....
Old Dec 30, 2004 | 10:02 AM
Hyaboosta's Avatar
congrats. not too shabby on the numbers
Old Dec 30, 2004 | 10:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">we ran into alot of gay problems , the car didnt even get onto the dyno till like 2 am.....modacar stayed till 330 and finally called it quits , boy is that shop ******* awsome i have to add , they were there for like 15 hours tuning all day with mase...
but from one hour of actual tuning i did , i based at 208 199 , then a little tuning at 13 lbs it made 263whp 247 tq.....not bad for stock tb , im and head.....</TD></TR></TABLE>
adseguy's Avatar
Holly torque curve batman.
Sweet torque . Most people don't see that until they break the 300whp. Have fun!
Old Dec 30, 2004 | 10:17 AM
ATS*Mark's Avatar
OG triple OG
Default Re: the time has come.... (adseguy)
i was impressed to say the least
the car will make 300 im sure at 15 lbs tuned...
Old Dec 30, 2004 | 10:51 AM
macrosshn's Avatar
the son and the heir
pretty impressive numbers Mark, I can't wait to have my set-up installed and tuned.
Old Dec 30, 2004 | 10:55 AM
mooook's Avatar
Default Re: the time has come.... (macrosshn)
im lovin the built turbo ninja.
Did you post these on TurboD yet?
Old Dec 30, 2004 | 10:57 AM
ATS*Mark's Avatar
OG triple OG
Default Re: the time has come.... (mookvtec)
not yet , thanks for the compliments.
