Light Bulbs
Old Dec 26, 2004 | 10:45 PM
AccordHawk36's Avatar
Default Light Bulbs
Instead of getting HID's I was just wondering about PIAA bulbs? Good or Bad...b/c I dont really want to mess with any electrical stuff b/c I dont want to void my warranty. I dont know really... All I want is Hyper White Bulbs
Old Dec 26, 2004 | 10:50 PM
ericjackson's Avatar
Default Re: Light Bulbs (AccordHawk36)
i dont know too much about the PIAA, but i have silverstars and they work great for me. i have a post where i did a comparison to hid and silverstar.here you go
left is hid, right is silverstar. and its a nice white light. not very blue if any
Old Dec 26, 2004 | 10:51 PM
Default Re: Light Bulbs (ericjackson)
I See... So the Silverstars are a lot brighter than the Stock Headlight?
Old Dec 26, 2004 | 10:59 PM
oh yeah, to me.. one night it was raining real bad. and i had just regular halogens. i couldnt see ****. so the next day i got these. and i havent used anything else sense, i know someone who has the same car as mine with those xenon bulbs. and it is no comparison. i dont know to much about the piaa. i think there a bit more exp than usual, but i dont know
Old Dec 26, 2004 | 11:21 PM
Thanks a lot man... I think imma go check them out... any idea where the cheapest place is... i think i saw them at Pepboys?
Old Dec 27, 2004 | 10:38 AM
accord115's Avatar
ebay
Old Dec 27, 2004 | 10:50 AM
accordselux's Avatar
Me Gusta History
Default Re: Light Bulbs (accord115)
Yea i saved 15 bucks getting my silverstars on ebay vs. pep boys.
Silverstars have my vote, i'm very happy with them.
Old Dec 27, 2004 | 07:46 PM
i just get mine at walmart. i dont trust too much off ebay. but if you do, go for it. and what i did, i aimed my headlamps up a little and it covers hella room
Old Dec 27, 2004 | 08:54 PM
sj993's Avatar
Default Re: (ericjackson)
I had PIAA's on mine before I got HID's. A little better than stock, but not a whole lot. I can say they were very reliable compared to cheaper aftermarket bulbs.
Old Dec 27, 2004 | 09:52 PM
CD7power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericjackson &raquo;</TD></TR><TR><TD CLASS="quote">i just get mine at walmart. i dont trust too much off ebay. but if you do, go for it. and what i did, i aimed my headlamps up a little and it covers hella room</TD></TR></TABLE>
at the wal-mart over here silverstars at only $37.00 for a pair vs. $20.00 each at pep boys or kragen
Old Dec 28, 2004 | 12:19 AM
outersquare's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordHawk36 &raquo;</TD></TR><TR><TD CLASS="quote">I See... So the Silverstars are a lot brighter than the Stock Headlight?</TD></TR></TABLE>
No they're not. Silverstars are rated for the same lumens output as basic halogen bulbs. Some people believe they are brighter because they replaced old, existing bulbs. Halogen bulbs dim over time with usage.
http://www.sylvania.com/Consum...s.htm
http://www.sylvania.com/Consum...Line/
Also, Silverstars have much shorter rated lifespans than standard/stock. Late model accords typically use 9006 low beams, which silverstars are rated at almost 1/10th the life;
1 9006 1,000 hrs (standard)
6 9006 150 hrs (silverstar)
http://www.sylvaniaautocatalog...0,131
Old Dec 28, 2004 | 12:56 AM
Default Re: Light Bulbs (outersquare)
Thanks a lot man that helps a lot... Okay then what do i go with if i dont want the hids and just want the blue or the brightness or both?
Old Dec 28, 2004 | 01:41 AM
lv6l's Avatar
i had silverstar before i got my HID too, yes i would say silverstar works good, but if you want it a bit brighter get the 9005 silverstar and convert them into 9006 by cutting out the "smallest" teeth on the bulbs and shaving down the line in the bulb housing. you will get the brightest bulbs you can buy that is non-hid. but again if you can afford hid, i say go with hid. a good one will run you from 200 to 400. i got mine for 300. 8000k has white-blue color but now planning to get 6300k because i want a bright white look.
Old Dec 28, 2004 | 02:41 AM
Intense3.2's Avatar
Default Re: (lv6l)
i had silverstars for a while, but the kept blowing out about every 2-3 months... got tired of paying $20 a bulb... but many people have asked if i had h.i.d.'s when i had em in.
Old Dec 28, 2004 | 06:42 AM
FSTASNTZ's Avatar
Default Re: (Intense2.2)
I am currently using Wagner Tru View, I think they were a couple dollars less that the Silverstar, but seem to be just as clear and crisp at night.
Jason
Old Dec 28, 2004 | 06:57 AM
SpeedFreak77's Avatar
Default Re: (FSTASNTZ)
I know nothing about HID but I would like to put them on my car, about how long do the bulbs last. Does anyone know of a good company to go through?
Old Dec 28, 2004 | 03:53 PM
lv6l's Avatar
if being installed properly in a proper car that has no electrical problem it should last you for a pretty long time, maybe 10 years plus! my silverstar been lasting me for over a year now using on a daily basic and i bet it'll last even longer but i took them out for my HID. but i had stock hologen bulbs on my old car, an 85, i kept every stock and the bulbs still last just as good.hahahah
Old Dec 28, 2004 | 04:12 PM
dmurphy2k3's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 &raquo;</TD></TR><TR><TD CLASS="quote">i had silverstars for a while, but the kept blowing out about every 2-3 months... got tired of paying $20 a bulb... but many people have asked if i had h.i.d.'s when i had em in.
yea, i've had some in for a few months and i already had one burn out, id say silverstars aren't worth it becasue they burn out so much. For a set of 4 i spent 60 bucks and with how often you have to replace them you might as well get the hids. does anyone know if these hid kits are any good, they are really expensive,
http://www.hidexpress.com
or does anyone know any other good places to get HID?
Old Dec 28, 2004 | 07:19 PM
Default Re: (dmurphy2k3)
damn those hids seem pretty nice... and easy to install... will it not short anything out?? (electrically?)
Old Dec 28, 2004 | 09:11 PM
Shinbo's Avatar
Default Re: (AccordHawk36)
i've been using silverstars on my 04 accord for about 3 months now... haven't burned out on me yet and i love how they look. here's a picture of my car with silverstars:
Old Dec 28, 2004 | 09:22 PM
Default Re: (Shinbo)
If some of you guys are dead set on trying Silverstars, keep an eye on pepboys ads. They run sales for 20-30 on a pair. No need to sink 40+ since they're probably gonna burn out in 3-4 months anyways.
Old Dec 29, 2004 | 01:27 AM
lv6l's Avatar
the HID kit up there are good but too expensive, i say best is either buy them used from someone or if you want it new go on ebay and search for your bulb size but if all you guys are driving accord search for 9006 hid conversion.....buy either 6000k to 8000k because it looks nicer and you get a better light output compare to the 10k or higher its purpleish, and its stand out and everythign but it's not bright and its also illegal in some states. i say the 6000k or around there should be a good deal if you want pure white and bright.
Old Dec 29, 2004 | 01:36 AM
lv6l's Avatar
here are pics of HID on my car, i just finish retrofitting them and didn't have time to alligned them but this is 8000k hid bulbs i bought off ebay for 280 made from japan. i was happy from what i got.
Old Dec 29, 2004 | 06:09 AM
dmurphy2k3's Avatar
Default Re: (lv6l)
thanks, ill check out ebay
Old Dec 29, 2004 | 08:45 AM
skabone's Avatar
I had PIAAs and silverstars and I'd say go with the silverstars. I had my PIAAs for just over 2 years, but they were a bit pricy. the silverstars cost a lot less and they are just as bright.
