want to build up my GSR!
I got this from one board:
Here's a low 13 second all motor build-up for your Integra:
-Get a 4 into 1 header
-JDM ITR oversized pistons
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
-B&M fuel pressure regulator
-Bigger throttle body (match port with Skunk2 manifold)
-Clutch & lightweight flywheel
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
good luck,
Jared
Jun or Toda cams would be a great upgrade along with a port and polished head. Just remember that with the larger cams and higher revs you are going to need to upgrade the valve springs and retainers.
[Modified by 91civic, 1:38 PM 1/7/2002]
ya know, you should just try some 'R' cams for now then upgrade later.
Just so that you can experience the differences later on. R cams are way more affordable than any of the other non-OEM cams out there....well unless your mr. moneybags and you can afford all that at once....
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
-CTR camshafts
-cam gears
-Skunk2 manifold
-Chipped ECU
[Modified by B18CivicHB, 4:34 PM 1/7/2002]
blkgsr03
25
Jul 7, 2011 04:36 PM
TeamSTEALTH GSR
12
May 12, 2004 12:40 PM
