calling experienced engine builders to help me
Old Dec 26, 2004 | 06:20 PM
4drsedaneg's Avatar
Default calling experienced engine builders to help me
im ready to put my bottom end togeather on my h22, when i bought the motor it was all apart from a friend, i need to buy new bearings,i had the crank polished and some other things done, but i measured all the crank jurnals, and got the codes of the crank and the motor for the sizes, because this is my first build i have no clue what to use for oil clearence, and i have no clue how to figure out what bearing colors to get because i dont have the bearings to use plasticgauge on. so how do i go about this. if any one has like a color to thickness chart, or has advice or can help me please respond or PM me.
thanks
josh
merry xmas
Old Dec 26, 2004 | 06:25 PM
pb16b's Avatar
Default Re: calling experienced engine builders to help me (4drsedaneg)
plastigauge or mic'ing everything out are the only ways to get bearing codes (sizes).
Old Dec 26, 2004 | 06:34 PM
4drsedaneg's Avatar
Default Re: calling experienced engine builders to help me (pb16b)
i have all the crank jurnals mic'ed, as soon as i get my tq wrench im gonna put the main caps and main studs in and measure the main bore and rod bores, but i dont have the og bearings- so how do i find what size bearings to use
Old Dec 26, 2004 | 06:36 PM
4drsedaneg's Avatar
if some one can help me out, i will pm them all my measurments if they can figure out what bearing specs im gonna need
Old Dec 26, 2004 | 07:22 PM
4drsedaneg's Avatar
bump
Old Dec 27, 2004 | 04:46 AM
4drsedaneg's Avatar
i know there is some one here who can help me
Old Dec 27, 2004 | 06:54 AM
Scotty B's Avatar
It will be in the factory service manual. You should pick one up if you putting a bottom end together. Seriously the best 60 bucks you will have spent in a long time!! It has a chart in the manual.
Old Dec 27, 2004 | 08:43 AM
lohatch's Avatar
there should be stampings on the crank and the block. they correspond with each other and give you the factory bearing colors.
Old Dec 27, 2004 | 02:11 PM
4drsedaneg's Avatar
Default Re: calling experienced engine builders to help me (lohatch)
i have a helms book, but i cant make ence of this stuff, i have all the codes from the crank and motor they read like this
(flywheel to pully)
main jurnal 23446
main bore 32334
rod jurnal ccbc
rod bore 2232
i have miced the crank to
(flywheel to pully)
mains
49.99mm 49.985mm 49.97mm 49.98mm 49.96mm
rods
47.98mm 47.97mm 47.975mm 47.975mm
Old Dec 27, 2004 | 08:31 PM
4drsedaneg's Avatar
bump
mtseidl
Welding / Fabrication
Sep 10, 2012 08:36 PM
killerpenguin21
Jul 23, 2006 12:42 PM
scratchy
Mar 17, 2004 02:49 PM
jisu009
Jan 26, 2004 04:13 PM
90teg
Jul 24, 2003 09:10 AM
