Spoon cams or toda c's?
Old Jan 6, 2002 | 02:30 PM
civictyper85's Avatar
Default Spoon cams or toda c's?
I have a 98 type r motor. I/H/E/vafc and have skunk 2 cam gears not installed. I am going all motor: thin head gasket, shaving the head, upgraded valve terain. I have a straight pipe to tanabe rm exhaust i am wondering what would be a better application with this setup and still be some-comfortable street driving while getting max performance. Toda B's or spoon cams??
CHris
Old Jan 6, 2002 | 02:43 PM
sgT's Avatar
sgT
Default Re: Spoon cams or toda c's? (civictyper85)
thin head gasket + milled head = no toda Bs for you
Go with spoon cams if thats what you want. But you still need more mods
to get the most out of them. Ditch the tanabe as well
Old Jan 6, 2002 | 05:04 PM
garagespecial
Guest
Posts: n/a
Default Re: Spoon cams or toda c's? (sgT)
toda C with toda valves/springs should work well on your R dropping cams in a stock car wont make much of a difference like sgt said
[Modified by garagespecial, 6:04 PM 1/6/2002]
Old Jan 6, 2002 | 05:05 PM
mafay2's Avatar
New User
Why he need to ditch Tanabe? Are you saying that with the specB, you will need at least 2.5" ID exhaust?
Old Jan 6, 2002 | 05:07 PM
sgT's Avatar
sgT
Default Re: Spoon cams or toda c's? (mafay2)
tanabe has a few bottlenecks in it.
and it looks ugly lol
Old Jan 6, 2002 | 05:16 PM
Back in Black's Avatar
Rather OG
A matter of taste indeed...
The bottlenecks can be removed quite easily. Contact David Stadulis (aka SMSP) for more info.
Jason- who has a bottleneck free Tanabe
Old Jan 6, 2002 | 06:15 PM
Default Re: Spoon cams or toda c's? (Darth VadeR)
I said i was upping the valveterrain. Im getting portflow retainers and springs. Shaving the head 20 thousands and using a thinner head gasket. Im deciding toda b's or spoon cams. With this setup toda b's ive heard runs of high 12's on slicks....
Old Jan 6, 2002 | 06:18 PM
NAB20C5's Avatar
why are you milling your head?...in my opinion don't mill the head and build compression through pistons...therefore you will not have to worry about valve to piston clearance...if you decide then I would clay your combustion chamber then decide on the cams...
an2ny888
May 3, 2005 08:27 PM
Engn
Honda S2000
13
Sep 24, 2003 02:13 PM
NightHawkC5
Honda S2000
10
Aug 31, 2003 11:04 PM
Hard2Find
Aug 8, 2002 02:23 PM
AllMotorITR
Oct 7, 2001 07:22 PM
