86 honda accord start problem need a little help
Old Dec 26, 2004 | 12:33 PM
Mx3Kfze's Avatar
Default 86 honda accord start problem need a little help
Ok im no expert in dealing with hondas at all, but i have a theory of whats wrong.
Ok so when you try to turn the car over with the key the starter wont kick over, so i instantly went and checked teh starter and the silenoid both work, so i charged the battery and tried again and nothing. I tried in park and in neutral (car usually cranks when in neutral) still nothing so i put the key into the on position and i took a 12v wire and jumped from the battery to the starter to see if it would crank, and after 2 turns the car cranked right up.
So here is what my delima is i know about how mazda engines and electrical is setup but ive never even messed with a honda. So on my mx3 this problem would be the neutral switch but my mx3 is a manual, the accord is an automatic. So im guessing there is still some type of switch, maybe a park switch? if so if anyone know's where this is located or what else i might wanna check hell if you've had something similar to this problem id appreciate any help i can get.
Thanks in advance
Old Dec 26, 2004 | 07:12 PM
Vanilla Sky's Avatar
yes, there IS a switch... won't crank when the car is in any drive gear or reverse...
did you also check your fuses? problem could be there, too...
and http://www.3geez.com has more answers on the topic of third gen accords than honda-tech... give them a shot...
Derick
Old Dec 31, 2004 | 04:54 AM
dirtracer's Avatar
Default Re: 86 honda accord start problem need a little help (Mx3Kfze)
check your ground on the tranny to the front of the starter; had that happen to me
kv1
Honda Accord (2013 - 2015)
Aug 18, 2019 08:00 PM
godinez90
Jun 9, 2015 09:04 PM
VANGASKHAN
May 28, 2014 11:20 AM
LS1SSM6
Aug 25, 2011 05:51 AM
mellophonium
Nov 5, 2008 04:56 PM
