Coolant Tube Broke (pic included) - What to do?
Old Dec 26, 2004 | 07:22 AM
fausz's Avatar
Default Coolant Tube Broke (pic included) - What to do?
The picture below shows part of the cooling system and heater hoses. The red arrow points to what I've always heard of as a nipple, but I'm not sure what it's really called. It's where the heater hose attaches to.
My problem is that I've been tracking down a coolant leak on this newly rebuilt engine that's never been started yet and was thinking it was coming from the water pump inlet pipe. When I took the hose off the yellow highlighted nipple, the metal nipple broke off (see second pic).
I'm assuming that this is a part that just gets pressed in, can anyone confirm?
If so, anyone know of a part number if this is the case, or if a company like Napa carries it? Can this be installed using a rubber hammer?
Thanks for any advice!
Old Dec 26, 2004 | 07:31 AM
LSVTEC 91 Civic's Avatar
Banned
Clean out the hole, and tap new threads in. Get a fitting for it from ACE hardware.
Old Dec 26, 2004 | 07:36 AM
fausz's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Clean out the hole, and tap new threads in. Get a fitting for it from ACE hardware. </TD></TR></TABLE>
There don't appear to be any threads either on the nipple or inside where it should have been, which is why I was thinking it was pressed in, but I'll keep this in mind.
Old Dec 26, 2004 | 08:00 AM
UltimX's Avatar
Default Re: (fausz)
its pressed in, tap the hole for threads and then place a fitting inside there. The tube is hard to get out from a head if you wanted one.
Old Dec 26, 2004 | 08:02 AM
CRXBart's Avatar
Default Re: Coolant Tube Broke (pic included) - What to do? (fausz)
Bah, it's just your car's way of telling you it's time for an upgrade. What engine do you have?(Looks like d-series)
d-series- Y8 manifold
b-series(not gsr)- AEBS time
either way it won't cost too much, probally spend some of your x-mas money, and make more power too. I just wouldn't waste the time. How the hell did you break that anyway?
Old Dec 26, 2004 | 08:12 AM
Rostr02's Avatar
Default Re: Coolant Tube Broke (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
How the hell did you break that anyway?</TD></TR></TABLE>
I would like to know this also
Old Dec 26, 2004 | 08:19 AM
fausz's Avatar
Default Re: Coolant Tube Broke (Rostr02)
Yeah, I looked at it for several seconds thinking the same thing. I just pulled on it, and not hard either. So, I'm guessing it's not my water pump inlet pipe. It's almost clean on the inside also. This is from the CRX SI I bought for $200 with a blown head gasket. It's better to find this now than an hour away from home!
I'll check with honda and let you guys know what I come up with. I always get the weird issues!
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Bah, it's just your car's way of telling you it's time for an upgrade. What engine do you have?(Looks like d-series)</TD></TR></TABLE>
I agree. The best fix would be a new intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">The tube is hard to get out from a head if you wanted one.</TD></TR></TABLE>
Once I pulled the vacuum port in the intake for the brake booster. It was pretty tough. I had to use some map gas and some channel locks. I bet it will be damaged before you get it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">How the hell did you break that anyway?</TD></TR></TABLE>
Looks like it rusted.
Old Dec 26, 2004 | 08:23 AM
Wes V's Avatar
It's a "press-in" fitting from the factory.
My recommendation would be to look for a thread in fitting and then tap the hole for the fitting. This assumes that there is enough material around the diameter of the hole.
Another problem that you may bump into is that all of the hose fittings I've seen are for standard american hose sizes and will not give perfect fit for the factory metric size hoses. Plan on having to tighten down the hose clamp a lot and not using the standard honda clamp.
Wes
Old Dec 26, 2004 | 08:31 AM
UltimX's Avatar
Default Re: Coolant Tube Broke (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like it rusted.</TD></TR></TABLE>
Theres no doubt in my mind that it can be done. But its most likly going to bend the pipe and or crimp it than be feasable to take it out and press it back into the hole.
That piece rusted an broke off. I've seen it happen before. Use Antifreeze instread of water.
Old Dec 31, 2004 | 07:40 AM
fausz's Avatar
Do you have suggestions for a replacement intake if I don't get this one fixed? I'll try tapping the hole first, but if I have problems, I'd like to have alternatives. If there are other intakes out there that wouldn't require a lot of money or a lot of tinkering then I may be interested, but I don't want a science project! Thanks!
Old Dec 31, 2004 | 07:42 AM
fausz's Avatar
This is my first option. I've tried everyone but Ace, I'll go there next because nobody else has anything that will fit.
Phil
Old Dec 31, 2004 | 08:33 AM
RCautoworks's Avatar
Default Re: (fausz)
I would probably just replace the whole intake, if your not looking to spend a lot look into the aebs one, or just by a stock replacement.
Old Dec 31, 2004 | 08:55 AM
CRXBart's Avatar
Default Re: Coolant Tube Broke (fausz)
If you have an just an old A6 in your Si still, then get a 96-00 EX(D16Y8) civic's manifold. Get a 5-speed one because it will go on with less mods. You can probally get them at a junk yard for a reasonable price. I got mine, w/ my z6 swap for $100 from a local yard. I wouldn't pay more than $50 for that manifold.
Old Dec 31, 2004 | 09:46 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fausz &raquo;</TD></TR><TR><TD CLASS="quote">The picture below shows part of the cooling system and heater hoses. The red arrow points to what I've always heard of as a nipple, but I'm not sure what it's really called. It's where the heater hose attaches to.
I've got a 5spd Z6 manifold sitting in my garage from a swap...has rail/inj's/tb
Let me know it's collecting dust. $50?
Vince
Old Dec 31, 2004 | 09:48 AM
UltimX's Avatar
Default Re: Coolant Tube Broke (AgentJam)
Get one from a junk yard or someone else on this board. Thats the other alternative unless you want to tackel this project.
Old Dec 31, 2004 | 10:01 AM
dr_latino999's Avatar
Default Re: Coolant Tube Broke (UltimX)
I am switching over to the Y8 manifold on my A6 this week, but I will have two spare A6 manifolds laying around when I'm done, hint hint.
Old Dec 31, 2004 | 10:27 AM
NFM_Dm's Avatar
Default Re: Coolant Tube Broke (dr_latino999)
that happned to me. i just swapped.
EFProjectHatch
May 12, 2015 06:25 PM
zdizzle
Mar 10, 2008 10:50 AM
low91rex
Mar 26, 2007 06:06 PM
yOnKiNaToR
Sep 20, 2006 10:46 AM
filthyCREX
Dec 1, 2003 09:57 AM
