Im new to building a turbo kit and i need help with the wastegate on a blox manifold!
i have heard that blox manis are known for the wastegate hitting the head or valve cover. any suggestions on what i should get or do? and i also need to find a turbo to fit this manifold it says t3 but not sure what to get nothing too tiny but nothing crazy...
It is only a slight problem. Some wastegates hit, some don't; within manufacturing tolerances, which are generally large on cast parts.
If you get one that hits, your best bet would be to shim out the manifold and/or the wastegate with extra steel shim gaskets. Failing that, a touchup at the machine shop would easily fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bl
VlW313 »</TD></TR><TR><TD CLASS="quote">get a turbosmart wastegate.
vestalfootball72
Feb 19, 2007 01:33 PM
