any one with 85mm sleeves ?
Old Dec 25, 2004 | 07:24 PM
radeon's Avatar
Default any one with 85mm sleeves ?
any one have any problems with 85mm sleeves ??
like with the head gasket or any other problems
Old Dec 26, 2004 | 04:04 AM
asubennett's Avatar
Default Re: any one with 85mm sleeves ? (radeon)
Zero problems with 85mm. There is plenty of room between the cylinders to get gasket to seal.
Old Dec 26, 2004 | 06:44 AM
b19coupe's Avatar
Default Re: any one with 85mm sleeves ? (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Zero problems with 85mm. </TD></TR></TABLE>
Ditto. Ran my 85mm motor for 15k + miles. Many dyno passes and trips down the 1/4.
Old Dec 26, 2004 | 07:50 AM
radeon's Avatar
what kind of head gasket are you guys using??
Old Dec 26, 2004 | 07:59 AM
b19coupe's Avatar
Default Re: (radeon)
Bored OEM.
Old Dec 26, 2004 | 08:52 AM
asubennett's Avatar
Default Re: (b19coupe)
Cometic with the forced induction ring.
Old Dec 26, 2004 | 10:28 AM
gaskleppie's Avatar
How can you bore out a stock gasket?
And are you talking about a B18 gasket or a B20 gasket?
Old Dec 26, 2004 | 10:33 AM
asubennett's Avatar
Default Re: (gaskleppie)
look at GE gaskets. THey are overbored stock
Old Dec 26, 2004 | 07:17 PM
sleepycivichb's Avatar
He's talking about overboring it from a b20, from 84mm to 85mm. but I'm just using cometic. -Jason
Old Dec 26, 2004 | 08:59 PM
gaskleppie's Avatar
Thanks!
Im going 85mm too and I still havent got a gasket!
Old Dec 26, 2004 | 09:32 PM
Big Teggie's Avatar
85mm is a good. I use Cometic gaskets and have zero problems.
Old Dec 26, 2004 | 10:46 PM
B20vtec86crx's Avatar
Default Re: any one with 85mm sleeves ? (Big Teggie)
stock 1 layer bored out to 85mm haven't had any problem
Old Dec 26, 2004 | 11:21 PM
rhd's Avatar
rhd
85mm on AEBS sleeves....running cometic HP
Rheg6
20
Sep 16, 2009 07:45 PM
b16 matt
Jan 30, 2008 11:53 AM
W O T
Mar 23, 2006 12:57 AM
thor559
Sep 13, 2003 01:50 AM
boomslang
Sep 30, 2002 04:51 PM
