problems with overheating in 1996 accord please help.
Old Dec 25, 2004 | 05:47 PM
bioscivicsi's Avatar
Default problems with overheating in 1996 accord please help.
my accord has a overheating problem. the car has 130000 miles on it. i all ready change the raidiator, thermostat, both sensors, the fan and check all fueses and realys what eles can it be.please help .
Modified by bioscivicsi at 10:05 PM 12/25/2004
Old Dec 25, 2004 | 05:56 PM
TOAB's Avatar
Default Re: problems with overheating in 1996 accord please help. (bioscivicsi)
do you happen to have any coolant or oil?
sorry for the dumb question, but i've read some really dumb stuff on here. (example: "i dropped a bolt into my head, and ive been driving around. its still perfectly fine")
Old Dec 25, 2004 | 05:59 PM
Default Re: problems with overheating in 1996 accord please help. (TOAB)
yes also did a flush and change oil.
Old Dec 25, 2004 | 09:30 PM
jaykup's Avatar
Did you notice the fan kicking on when it starts to get hot? Do you get heat through your vents?
Old Dec 26, 2004 | 08:04 AM
iam7head's Avatar
Default Re: problems with overheating in 1996 accord please help. (jaykup)
1. check coolant level(what color is it? coffee color? milky?,etc)
2. check for big **** leaks
3. check if the fans are kicking in or not(beating the hell out of it in local street)
4. timing
Old Dec 26, 2004 | 08:20 AM
BudYsr's Avatar
Default Re: problems with overheating in 1996 accord please help. (iam7head)
Also it is possible that even though you changed the T-stat that its still the problem. I have seen brand new T-stats be defective. Not likely but still something to consider....
Old Dec 26, 2004 | 08:22 AM
iam7head's Avatar
Default Re: problems with overheating in 1996 accord please help. (BudYsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudYsr &raquo;</TD></TR><TR><TD CLASS="quote">Also it is possible that even though you changed the T-stat that its still the problem. I have seen brand new T-stats be defective. Not likely but still something to consider....</TD></TR></TABLE>
in matter of fact, the waxball size do vary a little bit especially if you get them at any place beside honda.
in other word, go with oem
Old Dec 28, 2004 | 08:36 PM
just want to say thanks for the help, i will buy a new oem t-stat. fan does come on ,someone suggested the water pump what do u think?
Old Dec 30, 2004 | 11:15 AM
tr3-2001SE's Avatar
You can check the water pump by pulling a hose and using a water hose to make sure the thing is pumping water. You can check the thermostat by removing it completely. If it still overheats it could be the radiator not flowing well. Again water hose will tell you if it is going through and slightly clogged. If all these systems seem to be working and it still overheats it is probably a head gasket. almost forgot it can be the radiator cap. Should be the first thing you replace as it is usuallly cheap.
Old Dec 30, 2004 | 11:21 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bioscivicsi &raquo;</TD></TR><TR><TD CLASS="quote">just want to say thanks for the help, i will buy a new oem t-stat. fan does come on ,someone suggested the water pump what do u think?</TD></TR></TABLE>
you know it if the water pump stop working, it will give you smoky mess once you get off the freeway. not to mention code 25, code 3
aimeewest
Apr 10, 2015 06:25 PM
lazychina
10
Jun 30, 2011 07:16 PM
abaaj
Feb 22, 2005 04:54 PM
magnet05
Aug 9, 2004 06:48 PM
professorman
Nov 8, 2002 04:51 PM
