**HOW DO YOU INSTALL A SHORT SHIFTER?**
Old Dec 25, 2004 | 01:17 PM
fast90hatch's Avatar
Default **HOW DO YOU INSTALL A SHORT SHIFTER?**
I just bought a short shifter for my 1990 civic.. I have installed short shifters on RWD cars before but i have never installed one or seen one being installed on a FWD car. so i would like to know how to do it. Right now i have the center console off my car and i have the boot off. Im stuck!! i don't know what to do from here. It look like i have to go from the bottom. Is this correct. Can someone please tell me what to do?
Thanks.
Old Dec 25, 2004 | 02:28 PM
tcwcrxhf's Avatar
Default Re: **HOW DO YOU INSTALL A SHORT SHIFTER?** (fast90hatch)
I would start by removing the center console then raise the car up and go under it and start unbolting the linkages at the shifter and just bolt the new one up and be sure to use lithium grease
Old Dec 25, 2004 | 03:45 PM
erikiksaz1's Avatar
There should be a few tutorials.
Anyways, a few tips:
1) lube everything with lithium grease
2) buy new bushings
3) torque everything down to the proper specs
4) once the shift linkage bolts are loose, the whole thing will probably hang by the rubber boot, the rubber boot can disconnect from it.
It took me about an hour trying to find a way to work around the rubber boot, then i found out you could just yank the damned thing off
Old Dec 25, 2004 | 05:24 PM
crx90rcr's Avatar
Default Re: **HOW DO YOU INSTALL A SHORT SHIFTER?** (erikiksaz1)
when i installed mine i had no lith grease but i saw a tube of bike grease 4 the bearings and the chain its something 1000 grease i used it and it worked fine is that bad
Old Dec 26, 2004 | 09:36 AM
Default Re: **HOW DO YOU INSTALL A SHORT SHIFTER?** (crx90rcr)
thanks guys i got it in late last night. it feels great i love it. the throws are so much shorter and it goes into gear alot better. I used all purpose wheel bearing grease. i hope that isn't bad. but it seems to of worked fine. Thanks guys!
Old Dec 26, 2004 | 09:45 AM
Recluse03's Avatar
what kind did u get? i've had a cheapy ebay one which was nicer than stock, then i got a B&M which is damn sexy. i actually used bolt cutters and cut off the top 1/2 inch too. Its the distance between ***** that makes for the short throw, but i wanted to keep the shift boot nice and close to the ****, feels and looks great.
Old Dec 26, 2004 | 09:48 AM
ham's Avatar
ham
for the future..... all you need to do inside of the car is take the ball off.
i found it easiest to take the whole linkage off and change out the shifter in a vise and put it back in as a unit.
good job for figuring it out though.
Old Dec 30, 2004 | 06:33 AM
crx90rcr's Avatar
Default Re: **HOW DO YOU INSTALL A SHORT SHIFTER?** (ham)
man thats a good idea it took me about 2 hours under my car to get the bolt back in the shifter with the washers and stuff
Old Dec 30, 2004 | 09:37 AM
im not to sure what kind of short shifter it is. My bro got it for me for for x-mis. It has a integra type R shift **** on it tho. Looks really good. It didn't take me to long to figure it out at all. all i did was climb under the car, undo the shift linkage and then take off the two bolts that hold on the plate that hold on the ball. I had my bro in the car to hold the top of the bolt thing with vise grips. Then i greased everthing up and put the new one in. If anyone would like pics of the new one put in ill get some tonight! put a post up asking.
Old Dec 30, 2004 | 11:15 AM
rice a roni's Avatar
there was a link on here somewheres...lets see if i can find it.
taddaaaHHHHHHHHHHHHhhhhhhhhh.....
the wonderful search tool did it again...there you go sir
https://honda-tech.com/zerothread?id=1007935
now say thank you.
Old Dec 30, 2004 | 05:26 PM
Default Re: **HOW DO YOU INSTALL A SHORT SHIFTER?** (cr-ex)
wow mine was alot easier then that. i only did like half that stuff. i didn't have to take out the whole linkage or anything. and i got around the exhaust with universal's. ill be taking a bunch of pics of my car tomorrow and making another cardomian site for my Civic. so ill post the link up tomorrow.
nicko360
Feb 8, 2007 01:31 PM
lif3tak3n
Dec 2, 2005 08:16 AM
elevatethis
27
Aug 10, 2004 11:12 PM
Wattup Though 00
Mar 25, 2004 04:23 AM
erikjohn19
Sep 28, 2001 10:48 AM
