*HELP* Which motor to add a snail on question??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick GS-R »</TD></TR><TR><TD CLASS="quote">the b20 will be fine but sleeve it
yeah since the b20 have basically thinner sleeves they are more prone to cracking when boosting/pushin a lot of HP. the b18 has thicker sleeves and is good for about 300whp in it's entire stock form. Basically the b20 won't be as reliable with the thiner sleeves, but if you run lower HP you should be fine. It's up to you make an informed descision
</TD></TR></TABLE>yeah since the b20 have basically thinner sleeves they are more prone to cracking when boosting/pushin a lot of HP. the b18 has thicker sleeves and is good for about 300whp in it's entire stock form. Basically the b20 won't be as reliable with the thiner sleeves, but if you run lower HP you should be fine. It's up to you make an informed descision
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg »</TD></TR><TR><TD CLASS="quote">Boost the hell outa the crvtec yo!</TD></TR></TABLE>
foo shessy
foo shessy
