HELP .....tranny...gear getting stuck ..will not go into any gear's while running
Old Dec 25, 2004 | 02:32 AM
drevinder's Avatar
Default HELP .....tranny...gear getting stuck ..will not go into any gear's while running
car 95 gsr
driving down freeway down shifted to 4th slowing traffic then trying to put it back to 5th would not go tried to putting in to other gear's wouldn't go in-to any other gear's also pulled over and stop...turn off the car gear's seem to be working fine when car is off started the car again would not go in to and gear's ....then turned the car off again put in to second gear let the clutch engage then it started to drive ...
waited about an hour the car seems to be working fine...drove for another 10 minutes same thing again would not go in-to gear......
any help would be nice.....since the car is across the border (in Canada ) so i am limited to tool's up there....so i want to know what all i can check for just so i can bring it back to my house besides' paying to get it towed back home
thanks
Old Dec 25, 2004 | 08:48 AM
PrettyLude's Avatar
check your fluid first
Old Dec 25, 2004 | 11:53 AM
777sC's Avatar
Default Re: (PrettyLude)
any other comments .... iam gonna go pick up the car today ... hopefully ...
Old Dec 25, 2004 | 01:23 PM
Flexmyrex's Avatar
Default Re: HELP .....tranny...gear getting stuck ..will not go into any gear's while running (drevinder)
i had the same problem a few years ago in my crx, i had to readjust the cable because it was not engaging the clutch.
since your using a hydro line to engage the clutch i would check fluids, leaks, slave cylinder or bent fork. good luck
mnskateboarder
Transmission & Drivetrain
11
Oct 25, 2009 08:01 PM
ej8marvin
May 5, 2008 06:07 PM
xlusiveracer
Mar 7, 2007 08:48 PM
drevinder
12
Dec 30, 2004 10:58 AM
Larkin W.
Jul 29, 2003 08:01 AM
