Help put ls injectors
Old Dec 25, 2004 | 12:07 AM
efhatchster's Avatar
Default Help put ls injectors
i put ls injectors on m y sohc and they are not put out fuel properly 96 injectors help porfavor any body
Old Dec 25, 2004 | 12:12 AM
eda6's Avatar
Default Re: Help put ls injectors (efhatchster)
Did you remove the resistor box? If you install 92+ injectors you have to remove the resistor box.
Old Jan 4, 2005 | 07:46 PM
Default Re: Help put ls injectors (eda6)
yeah i did remove but my number 4 injector is not spraying right and it feels like **** im using my cousins si ecu and i put a ls throttlebody dunno what it is im just going o go gray plug **** the bull **** im dropping in a ls b18 i want toque and maybe il slap on a vtec head thank bro
Old Jan 4, 2005 | 07:50 PM
Malgerus's Avatar
Are you sure they're all wired up correctly? Double check all the wiring. Could be a loose wire. Also, perhaps you have one bad injector. Any leaks? See if you can borrow a similar injector and try it.
Old Jan 4, 2005 | 09:27 PM
Nerologic's Avatar
thats a waste of time and wiring, ur stock injectors would work the same as the ones u swapped in...
Old Jan 4, 2005 | 09:31 PM
doublethink's Avatar
did you think there was acutally some performance difference between these two when there isnt...?
Old Jan 6, 2005 | 07:57 PM
Default Re: Help put ls injectors (doublethink)
no not much it's not worth it
bigsnorlax
May 21, 2011 01:42 PM
8083tcman
Feb 2, 2009 12:59 PM
CivicxTree754
Aug 26, 2008 12:48 PM
INTEGRA_boy
Dec 13, 2005 12:22 PM
wrXtian
Jan 7, 2003 03:33 PM
