which tires??
I am stuck between two tires Falken Azenis ot Toyo T1-s? I did a search but came up with mixed results. I found the falkens for $60 each and the Toyos for $59 each. I need something that is good street tire and also some 1/8 mile track use. Which would you guys go with? Also I have 15" Rotas and I am lowered abou 1.5 on Ground Controls what size would you go with 195-50-15 or 205-50-15?
thanks
Matt
thanks
Matt
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
where did you find the T1S for that price?
ask yourself a question on the type of driving you will be doing, azenis do not handle water as well as the Toyo tyres, so keep that in mind.
stan
stan
I run Azenis up front and All Season GoodYears in back. Saved my life a time or two when regaining in the rain. I've only used the Azenis, so I can't compare the two, but the Azenis always seem to be wider than said in spec. They get my
- Darrell
- Darrell
well as of right now I can't get ant traction when I try to Launch even if the rpms are low and i feather the clutch. So I am trying to get a nice gripping tire that also handles well. Azenis look sexy but I think the t1s do too!
I got the prize on teh falkens at tire.com and the toyo prize I got from onlinetires.com
i think the falkens only come in 205/50/15.
nathanie1
Feb 10, 2005 03:20 PM
